johnd-mkiv Posted August 26, 2014 Share Posted August 26, 2014 Hello im grafting a supra r154 gearbox onto a small block chevy for my cobra project ive made the bell housing adaptor got to the final stages and now found the oem friction disk springs foul on the flywheel bolts Ideally I want a friction disk that's flat on one side to give me the clearance on the bolts, the only thing I can find is a paddle type clutch which im not really keen on, any one have anything laying about or know of a make of disk that will resolve my problem?? I cant machine the flywheel as theres not a lot of meat on it, I could countersink and install alen bolts but not sure if this is a wise move any help be greatly appreciated thanks Quote Link to comment Share on other sites More sharing options...
Guest FullAttack Posted August 26, 2014 Share Posted August 26, 2014 Don't compromise the flywheel bolts.. You could use an unsprung disc which wouldn't foul, but not that nice to use on a daily. I use ACT clutches usually, I think even the sprung discs are flat on one side.. I'll check later if I remember;) Quote Link to comment Share on other sites More sharing options...
johnd-mkiv Posted August 27, 2014 Author Share Posted August 27, 2014 I'm fairly sure my old act clutch was all on one side but googling pictures I can't find Any with both sides Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 27, 2014 Share Posted August 27, 2014 Photos of flywheel, bolts shown, and disc would help Quote Link to comment Share on other sites More sharing options...
johnd-mkiv Posted August 27, 2014 Author Share Posted August 27, 2014 Let me know if you need any more Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 27, 2014 Share Posted August 27, 2014 As it's symmetrical reversing it won't help, and I wouldn't be too keen on countersunk Allen bolts without a dowel between each bolt. You could spot face under each bolt head and run them shallower, but a small block is a torquey lump and the flywheel looks cast.... a bit iffy! I would contact Helix Clutches and see if they have a plate, or can build you one: http://www.helix-autosport.com/home-page/ Quote Link to comment Share on other sites More sharing options...
johnd-mkiv Posted August 27, 2014 Author Share Posted August 27, 2014 As it's symmetrical reversing it won't help, and I wouldn't be too keen on countersunk Allen bolts without a dowel between each bolt. You could spot face under each bolt head and run them shallower, but a small block is a torquey lump and the flywheel looks cast.... a bit iffy! I would contact Helix Clutches and see if they have a plate, or can build you one: http://www.helix-autosport.com/home-page/ Thanks Chris will give them a try Quote Link to comment Share on other sites More sharing options...
garethr Posted August 28, 2014 Share Posted August 28, 2014 The Aussies seem to like Toyota boxes for their V8s (although I don't know Holdens if are the same as SBCs), so it might be worth looking round some Australian sites. Quote Link to comment Share on other sites More sharing options...
