j_jza80 Posted January 3, 2016 Author Share Posted January 3, 2016 I can also fit the alloy knobs the cal switches come with, I designed the facia in such a way that it will work with either, but imo they're a bit OTT for my car. Quote Link to comment Share on other sites More sharing options...
Luxluc Posted January 3, 2016 Share Posted January 3, 2016 I do prefer the black OEM knobs. Quote Link to comment Share on other sites More sharing options...
Kendo11 Posted January 3, 2016 Share Posted January 3, 2016 Yeah they are a bit in your face Quote Link to comment Share on other sites More sharing options...
Andrew K Posted January 4, 2016 Share Posted January 4, 2016 That's a very tidy / neat job you've made of that cal switch facia assembled mate, I like it The silver knobs do let it down a tad but can you not get different types of knobs for the cal switches? The one in my motor is quite a bit different to yours. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 4, 2016 Author Share Posted January 4, 2016 That's a very tidy / neat job you've made of that cal switch facia assembled mate, I like it The silver knobs do let it down a tad but can you not get different types of knobs for the cal switches? The one in my motor is quite a bit different to yours. Yes, I've already sourced (and just collected) the OEM Toyota knobs for it. This is now what it looks like Quote Link to comment Share on other sites More sharing options...
mellonman Posted January 4, 2016 Share Posted January 4, 2016 100 times better mate looks great almost oem Quote Link to comment Share on other sites More sharing options...
Andrew K Posted January 4, 2016 Share Posted January 4, 2016 Yes, I've already sourced (and just collected) the OEM Toyota knobs for it. This is now what it looks like http://i297.photobucket.com/albums/mm203/j_s14a/Snoopy%20Supra/DSC_0649_zpsfwuvxght.jpg That looks so much better with the OEM knobs mate, as said already 100 times better Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 6, 2016 Author Share Posted January 6, 2016 I finished assembling the cal switch panel last night, and got the illumination tested Also, I've received my steering wheel back from being retrimmed at Hide n Seat in Durham. I decided to go for black nappa leather, with perforated leather details and dark grey stitching. Should tie in nicely with the green/grey dash panels and grey alcantara on my Recaros I had them thicken the handbrake handle slightly. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted January 6, 2016 Share Posted January 6, 2016 I like the new handbrake! Ive thought about getting my spare redone to match my steering wheel. Keep up the good work! Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted January 6, 2016 Share Posted January 6, 2016 nice work mate, hope to see this motor soon in person. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 6, 2016 Author Share Posted January 6, 2016 Next on tye list of little jobs, is to sort the current rear fog setup. Currently, like most Imports, it has an aftermarket switch. I never had it mounted, because I always wanted a neater, more oem solution. So, I'll be using a relay instead of a switch, activated when the front fogs are turned on. Part of the mot regs for fog lights means you need a warning lamp of some kind. I decided to mount a 5mm green led in the stock bulb failure warning light. So this is how it looks when activated. It's pretty simple, but just helps neaten everything up. And it doesn't interfere with the warning lamp bulb. Quote Link to comment Share on other sites More sharing options...
Timlowthian Posted January 6, 2016 Share Posted January 6, 2016 That is great work I love the fog light mod! Quote Link to comment Share on other sites More sharing options...
Luxluc Posted January 6, 2016 Share Posted January 6, 2016 Yes, I've already sourced (and just collected) the OEM Toyota knobs for it. This is now what it looks like http://i297.photobucket.com/albums/mm203/j_s14a/Snoopy%20Supra/DSC_0649_zpsfwuvxght.jpg That looks ace. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 6, 2016 Author Share Posted January 6, 2016 (edited) Next job... As the Syvecs uses a cal switch for traction control, I was left with a now redundant traction control switch on the dash. I decided that I'm going to use one of the buttons for the cruise control, and the other for rolling antilag So I started by stripping down the switch, and lightly sanding the paint off. The material underneath is translucent grey, and it had discoloured behind the lettering. Interestingly (or not ) the discolouration that occurs on the OEM illuminated dash switches occurs on the outside, not the inside. So I had to sand that back further until all the discolouration had gone. I then went to my local sticker supplier and had him make me some tiny 'cruise' and 'lag' stickers as masks. Once applied, this was then sprayed with a layer of satin black, followed by a layer of crackle black, followed by another satin black. This achieves a similar mild crackle effect as the factory switch surrounds. The buttons themselves are just satin black. This is the finished surround, the illumination is just for highlighting the effect I'm not 100% happy with the word 'lag', as the guy at the sticker place applied the masks (even though I didn't ask him to ) and didn't get it right. I might revisit it at some point, but I'm happy with it for now Just assembled the switch and fitted it, pretty happy with the results Edited January 6, 2016 by j_jza80 (see edit history) Quote Link to comment Share on other sites More sharing options...
Tomyspeedy Posted January 6, 2016 Share Posted January 6, 2016 Im loving how oem you're making this all look. Tasteful and well executed Quote Link to comment Share on other sites More sharing options...
Stonkin Posted January 7, 2016 Share Posted January 7, 2016 Really nice! Some lovely touches going into this car Quote Link to comment Share on other sites More sharing options...
MRX Posted January 7, 2016 Share Posted January 7, 2016 Top work mate! Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 7, 2016 Author Share Posted January 7, 2016 Cheers guys Tonight so far I've finally got my heated seats fully working off the factory switch. As per this thread: http://www.mkivsupra.net/vbb/showthread.php?327966-Heated-Seat-Switch-Pinout-and-PCB I've wired the seat heaters through a couple of relays. I'll post up some pics and a wiring diagram to the linked thread, and get a mod to sticky it for anyone else who fancies retrofitting heated seats. I've also been doing further work on the dash panel for mounting the Toucan display. I cut a slot in it for the wiring, which was almost heartbreaking as these were probably among the best set of facelift dash panels left, with no marks and every single tab still intact. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 8, 2016 Author Share Posted January 8, 2016 In addition to the above, I managed to get my retrimmed handbrake installed (much easier than I thought it would be, and also tightened it up a little), and pulled my dial cluster out to install my 220mph speedo I got from metal monkey, which matches the rest perfectly. I also took the opportunity to paint the needles, as they were looking decidedly faded. Quote Link to comment Share on other sites More sharing options...
Kendo11 Posted January 8, 2016 Share Posted January 8, 2016 Great work - the speedo looks completely oem. Quote Link to comment Share on other sites More sharing options...
Mondo HnS Posted January 8, 2016 Share Posted January 8, 2016 I was going to get a set of Metal Monkey dials for the Zed a while ago, but just never got around to it. They were ridiculously helpful during the design process. Couldn't fault them at all! Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 8, 2016 Author Share Posted January 8, 2016 Just been trying to sort out the fog light wiring today, which is proving much more difficult than anticipated. However the front fogs are wired, they don't seem to produce any voltage on any of the pins in the cabin more on that later I did pick up my plug cover from the paintshop though. The stock turquoise colour wouldn't really fit in with the new engine bay scheme, and I also had to get rid of the words 'twin turbo' from it Quote Link to comment Share on other sites More sharing options...
TheTurtleshead Posted January 8, 2016 Share Posted January 8, 2016 Nice and oem! Have to say though, mounted a few toucans, never had to cut a hole in the actual dash panel before, just in the 'infill' piece placed in the vent hole. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted January 8, 2016 Author Share Posted January 8, 2016 Nice and oem! Have to say though, mounted a few toucans, never had to cut a hole in the actual dash panel before, just in the 'infill' piece placed in the vent hole. Cheers That's the clock hole that I've covered over, the air vent is still there and I've screwed the Toucan to the dash instead of using the swivel mount, so I would have had to drill it anyway Quote Link to comment Share on other sites More sharing options...
supra_ufo Posted January 8, 2016 Share Posted January 8, 2016 looks great reminded me bought needle paint and its not come yet! Quote Link to comment Share on other sites More sharing options...
