Jake Posted March 22, 2003 Share Posted March 22, 2003 It was some kinda breather pipe or something that had come loose. http://www.btinternet.com/~duncandriver/Supra/LoosePipe.jpg It seems to fall off again real easy though. I suppose I need to replace the Y shaped plastic pipe connector thingy. Anyone know what it's correctly called? I'd have to get it from me local Toyota dealer, right? Quote Link to comment Share on other sites More sharing options...
Terminator Posted March 22, 2003 Share Posted March 22, 2003 It looks like the Y piece has lost an arm:eek: Quote Link to comment Share on other sites More sharing options...
Jake Posted March 22, 2003 Author Share Posted March 22, 2003 Originally posted by Terminator It looks like the Y piece has lost an arm:eek: Yeah that's why the hose keeps falling off. There's still some of the pipe there but it's shorter than it should be. Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted March 22, 2003 Share Posted March 22, 2003 I would sort that ASAP as that pipe goes to the fuel pressure regulator, quite an essential piece of kit. It sounds like you have been running extremely rich at idle which would be due to this pipe being disconnected. Your fuelling will be all over the show. Quote Link to comment Share on other sites More sharing options...
Jake Posted March 22, 2003 Author Share Posted March 22, 2003 Originally posted by Martin F Your fuelling will be all over the show. It's connected back up now. I've just bodged it up until I can get a replacement Y connector. Quote Link to comment Share on other sites More sharing options...
Guest Martin F Posted March 22, 2003 Share Posted March 22, 2003 Originally posted by dunk657 I've just bodged it up until I can get a replacement Y connector. In that case IMHO i wouldn't boost until you have it fixed up properly. Not worth the chance of buggering your engine. Quote Link to comment Share on other sites More sharing options...
Terminator Posted March 23, 2003 Share Posted March 23, 2003 I would get a T piece, as a temporary fix, they are avaiable from most motor spares shops. IMHO the original Toyota part, which is made of metal, is far more reliable that those cheap nylon bits. Quote Link to comment Share on other sites More sharing options...
