marbleapple Posted August 26, 2014 Share Posted August 26, 2014 Morning all Car has just passed its MOT 1st time without any issues On return from the garage I've noticed that the buttons on the heater control panel in the centre console are not lighting up and are unresponsive. The other units in the dash are working fine. Could it be related to the MOT test perhaps? The only time I've had this issue has been because I've removed the dash and forgotten to plug a connector back in. At some point I'll remove the dash quickly and just check there isn't a fault connection. I just wondered if there is anything else you guys would recommend that I check before messing around with the dash? Cheers Richard Quote Link to comment Share on other sites More sharing options...
AndyJax Posted August 26, 2014 Share Posted August 26, 2014 Gotta be either a blown fuse or loose connection at back,try lightly tapping the side of the dashboard works for me when my heater control lights dont always come on Quote Link to comment Share on other sites More sharing options...
jay200bhp Posted August 26, 2014 Share Posted August 26, 2014 could the off button be stuck in Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 26, 2014 Share Posted August 26, 2014 Rear fog light is part of MOT test, has someone wired it in a daft manner and it's testing has blown a shared fuse, probably in the RH footwell outer side panel. Quote Link to comment Share on other sites More sharing options...
marbleapple Posted August 26, 2014 Author Share Posted August 26, 2014 Thanks for the replies so far. Appreciated. Rear fog light is part of MOT test, has someone wired it in a daft manner and it's testing has blown a shared fuse, probably in the RH footwell outer side panel. Chris, Its a possibility but the car is a UK Spec so no real foglight sillyness. I usually have a Jap spec rear light fitted (I prefer them) but I swapped it over for a UK spec light prior to the test. It was a simply matter of plug and play. I will try check this though. could the off button be stuck in I'll give that a try. Could be an explaination. Gotta be either a blown fuse or loose connection at back,try lightly tapping the side of the dashboard works for me when my heater control lights dont always come on I confess that this is my usual approach to such things. I've already tapped it. My next plan was to see if the plugs were loose by removing the dash panel Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 26, 2014 Share Posted August 26, 2014 Just a random idea based on what things get tested that may not normally be actuated. Hopefully it's just a badly seated connector, good luck! I am going to do fuse kits for the drivers footwell fuse box that illiminate if blown, they are a right fiddle to mess with on a winter's night! Quote Link to comment Share on other sites More sharing options...
marbleapple Posted August 26, 2014 Author Share Posted August 26, 2014 Just a random idea based on what things get tested that may not normally be actuated. Hopefully it's just a badly seated connector, good luck! I am going to do fuse kits for the drivers footwell fuse box that illiminate if blown, they are a right fiddle to mess with on a winter's night! I'll be the first to put my name down Quote Link to comment Share on other sites More sharing options...
KLAMA Posted August 11, 2017 Share Posted August 11, 2017 Hi I've got the same problem. My heater panel is not working at all. It has working lights but that's all. Not even rear heated window works. It is completely off. I checked the fuses in engine bay and near gas pedal and they are all ok. The panel was resoldered and it didn't help. Any guesses what might be wrong? Quote Link to comment Share on other sites More sharing options...
Sheefa Posted August 12, 2017 Share Posted August 12, 2017 Sounds like its completely dead and need another mate. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 12, 2017 Share Posted August 12, 2017 Don't throw it away though, as these cars get older repairs on things that become unobtainable, like this might, or even is, may be possible, or the only way forward! Quote Link to comment Share on other sites More sharing options...
KLAMA Posted August 12, 2017 Share Posted August 12, 2017 Sure thing! I keep all parts which are in reasonable state Quote Link to comment Share on other sites More sharing options...
KLAMA Posted August 12, 2017 Share Posted August 12, 2017 Seems that There might some electrical problem because folding mirrors stopped working as well Quote Link to comment Share on other sites More sharing options...
Tyson Posted August 12, 2017 Share Posted August 12, 2017 Seems that There might some electrical problem because folding mirrors stopped working as well /QUOTE] With so many things dying at once have you checked all the earths are secure ? Quote Link to comment Share on other sites More sharing options...
KLAMA Posted August 13, 2017 Share Posted August 13, 2017 (edited) I didn't check the wiring yet. If you have any idea where to start checking I'll be thankful. Edited August 14, 2017 by KLAMA (see edit history) Quote Link to comment Share on other sites More sharing options...
KLAMA Posted August 15, 2017 Share Posted August 15, 2017 Checked The wiring and some wires near gas pedal were in very bad condition. Fixed it and both ac panel and folding mirrors started working. Somebody who was installing the alarm did bad job and messed harness up Quote Link to comment Share on other sites More sharing options...
Tyson Posted August 15, 2017 Share Posted August 15, 2017 Checked The wiring and some wires near gas pedal were in very bad condition. Fixed it and both ac panel and folding mirrors started working. Somebody who was installing the alarm did bad job and messed harness up /QUOTE] Nice to know it was an easy fix ! Quote Link to comment Share on other sites More sharing options...
