Guest Scotty 88 Posted August 25, 2014 Share Posted August 25, 2014 Hey guys! Quick question but does anybody know where's the best place to get the supra underseal in Scotland ??? Just don't want the rust to get hold of the car Quote Link to comment Share on other sites More sharing options...
Big Mark Posted August 25, 2014 Share Posted August 25, 2014 Why don't you get it up in the air and do it yourself? It'd not that hard. I did parts of mine this weekend. Top tip though is to wear some protective eyewer as undeseal in the eye isn't pleasant Quote Link to comment Share on other sites More sharing options...
Guest Scotty 88 Posted August 25, 2014 Share Posted August 25, 2014 I thought about it but I only have small car ramps plus the only garage I trust is closed for a a wee while now yea I've heard it's not the best thing to get in your eye, how did you get on with your car? Quote Link to comment Share on other sites More sharing options...
tony tt Posted August 25, 2014 Share Posted August 25, 2014 Any decent garage should be able to do it bud. It's not a hard job. Quote Link to comment Share on other sites More sharing options...
Scott Posted August 25, 2014 Share Posted August 25, 2014 Hire a ramp for an hour. Most independent garages will let you do this. Quote Link to comment Share on other sites More sharing options...
naybad Posted August 25, 2014 Share Posted August 25, 2014 Its not to hard to do m8 i can lend you acle stands if you need them. If not i use http://www.discoveryautos.co.uk/if i am not doing it my self. They do all my MOT's on the supra and niver take the piss. Quote Link to comment Share on other sites More sharing options...
Guest Scotty 88 Posted August 25, 2014 Share Posted August 25, 2014 Spot on guys I'll check it a few garages see if they can rent one out I'll chase discovery autos and see what they say Quote Link to comment Share on other sites More sharing options...
SPG Posted August 25, 2014 Share Posted August 25, 2014 What does the underside of your Sup currently look like, out of curiosity? You can cover the large areas of the underside with a brush and some underseal, but to do the job correctly and to get into the box sections and hard to reach areas, you ideally need a wand attachment. Also have a read online at the different treatment techniques and products which you can use to treat the underside before the underseal is applied, as otherwise you are merely locking in the rust, which will no doubt lead to more serious corrosion. Quote Link to comment Share on other sites More sharing options...
Guest Scotty 88 Posted August 25, 2014 Share Posted August 25, 2014 The condition is good for its age (21 years old ) there's slight signs of rust, I looked at different products and Schutz, Dinitrol and Carplan kept coming up I rather attack it ASAP before it gets worse and have to start welding but rather get it sort out soon, yea that's right if you look it in then more damage than good Quote Link to comment Share on other sites More sharing options...
Big Mark Posted August 25, 2014 Share Posted August 25, 2014 I had the front of my car up on axle stands so I could straighten out the seem tha gets flattened when people use a trolley jack inthe factory jacking locations and so decided to apply a couple of coats of underbody to along these areas, but last year when I had the car on 4 axle stands I got my exto do the whole of the underside. If she could do it anyone can. Quote Link to comment Share on other sites More sharing options...
Guest Scotty 88 Posted August 25, 2014 Share Posted August 25, 2014 Thanks man am going to have a look tomorrow are the stores e.g. Auto save and halfords and if not there then the net, do you still remember the product you used? If I got my ex do to it she would fiip and steal the car lol Quote Link to comment Share on other sites More sharing options...
Big Mark Posted August 25, 2014 Share Posted August 25, 2014 She wasn't the ex at the time, lol. I've got 2 tins here but not sure what I usd last year. I think it might have been Hammerite Underbody Seal with Added Wax Oil. I also havea tin of Carplan Tretroseal Underbody Sealant, which is the one I used this weekend. Quote Link to comment Share on other sites More sharing options...
Guest Scotty 88 Posted August 25, 2014 Share Posted August 25, 2014 Oh didn't know Hammerite did underseal might have a look that up I've heard of car plan they're common for car products, I looking to tackle it myself this weekend Quote Link to comment Share on other sites More sharing options...
Big Mark Posted August 26, 2014 Share Posted August 26, 2014 It's not a hard job mate, but make sure you wear goggles, I learnt the hard way! Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted August 26, 2014 Share Posted August 26, 2014 If you've already got signs of rust, get it to a professional to sort out. Even if that means traveling. Anyone who has dealt with classic cars before will know the issues incorrect application of under seal can cause. As has been mentioned, if you trap moisture in there, you'll end up with a rotten floor pan eventually. This is why it is also important to get underseal removed and replaced once it starts showing signs of flaking and cracking. I'd also look into cavity wax application too. Quote Link to comment Share on other sites More sharing options...
Ric Posted August 26, 2014 Share Posted August 26, 2014 You need to make sure underneath the car is BONE dry first, otherwise you are just sealing over moisture. I had mine done after it had been in the bodyshop for almost 2 months and a week in the oven, so no traces of damp or wet, hopefully. Quote Link to comment Share on other sites More sharing options...
Krister Posted August 26, 2014 Share Posted August 26, 2014 (edited) If you've already got signs of rust, get it to a professional to sort out. Even if that means traveling. Anyone who has dealt with classic cars before will know the issues incorrect application of under seal can cause. As has been mentioned, if you trap moisture in there, you'll end up with a rotten floor pan eventually. This is why it is also important to get underseal removed and replaced once it starts showing signs of flaking and cracking. I'd also look into cavity wax application too. ^This If your car bottom already has some rust and you apply underseal on it, it will rust under the sealant and at it will keep on rotting untill you have a hole. If there is rust, the rust needs to be removed with sandblasting and painted before underseal can be applied. Proper underseal treatment cant be done in an hour on ramps. Here's a video how you properly underseal a car: Edited August 26, 2014 by Krister (see edit history) Quote Link to comment Share on other sites More sharing options...
Guest c9aan Posted October 8, 2015 Share Posted October 8, 2015 (edited) Hello all, I am new to this forum but thought I may be of some assistance, I run my own Vehicle Undersealing Company. Looking forward to having fun on this forum and meeting some great enthusiast. Mark Edited October 8, 2015 by SPG Please see club rules on trading. (see edit history) Quote Link to comment Share on other sites More sharing options...
millar11 Posted October 8, 2015 Share Posted October 8, 2015 I got my car done at GI Motorsport. Car was in to get coilovers and exhaust done so got it done at same time. They were recommended to me by some club members. Quote Link to comment Share on other sites More sharing options...
Scott Posted October 8, 2015 Share Posted October 8, 2015 What was the cost millar? Quote Link to comment Share on other sites More sharing options...
millar11 Posted October 9, 2015 Share Posted October 9, 2015 Sorry for late reply Scott. To be honest I would need to check. Was pretty reasonable if I remember tho. Quote Link to comment Share on other sites More sharing options...
