J spec 93 Odometer not counting
Kazuma
Hey guys
Just a quick one - my odometer isn't counting and hasn't since I got the car. I took it into a garage and had some diagnostic work done, I was told the speedo was more than likely the cause. I purchased a used speedo converter from Kieron, and had this fitted. Either way, it's still not counting, speedo is though. Can anyone suggest what else to try? I've already spent just over £300 so far! Just on labour.
Is it possible to just get a replacement odometer?
Kaz
Hi,
I'm in a similar position.
I have a couple of questions, is the speedo in miles or kms?
Has there possibly been a converter fitted and then removed?
Looking at the cables behind the dash of my car and the fitting instructions for a speed converter/delimiter, it is clear from the wires that one was fitted and then removed. I'm in the process of determining whether it is simply that it's been wired back up incorrectly or whether it is the actual odo unit that's at fault.
Not sure how much help that is.
Cheers,
Ben
Anyone got any ideas?
Hey Ben, thanks for the response. The speedo is in mph. The converter has now been removed and a new fitted, however, prior to that, i'm not sure! I bought it from a car dealer and not the actual original owner. I'll let you know if I ever come to get mine fixed.
Thanks, Dave.
