Tommyd16 Posted August 24, 2014 Share Posted August 24, 2014 What's the best way to replace this. It seems to be stuck behind the ps pump aircon compressor Quote Link to comment Share on other sites More sharing options...
Scott Posted August 24, 2014 Share Posted August 24, 2014 Is it faulty? It's just a switch, I didn't think they were known to go down. If it's tricky to get to then removing the aux belt and PS pump/compressor is probably the easiest way. Quote Link to comment Share on other sites More sharing options...
Ian C Posted August 24, 2014 Share Posted August 24, 2014 They have been known to leak, Scott. And when they go, the leak gets much worse very quickly and you risk the engine running dry. Nasty. Quote Link to comment Share on other sites More sharing options...
Scott Posted August 24, 2014 Share Posted August 24, 2014 They have been known to leak, Scott. And when they go, the leak gets much worse very quickly and you risk the engine running dry. Nasty. Ahh that makes sense Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted August 24, 2014 Author Share Posted August 24, 2014 Yh it's very wet behind there. Is it hard to remove the ps pump? Can it moved out the way without removing pipes? Quote Link to comment Share on other sites More sharing options...
Guest FullAttack Posted August 24, 2014 Share Posted August 24, 2014 Easier to remove the ps pump.. It's a 27mm for the sensor iirc. Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted August 24, 2014 Author Share Posted August 24, 2014 Is it just two bolts behind the pulley that hold one the ps pump? Quote Link to comment Share on other sites More sharing options...
Rummy Posted August 24, 2014 Share Posted August 24, 2014 (edited) Is it just two bolts behind the pulley that hold one the ps pump? Deleted Edited August 24, 2014 by Rummy drunk logic (see edit history) Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted August 24, 2014 Author Share Posted August 24, 2014 From underneath for the power steering pump? Surly from above would be easier? It's right infront of you Quote Link to comment Share on other sites More sharing options...
Rummy Posted August 24, 2014 Share Posted August 24, 2014 My bad. I was thinking about something else. Note to self: don't drink and type. Quote Link to comment Share on other sites More sharing options...
Guest FullAttack Posted August 24, 2014 Share Posted August 24, 2014 It's probs easier to take the ps pump carrier off completely.. So it's a handful of 14mm bolts.. One on back of pump, one onto block at bottom left front, and one on the aircon pump, and one a bit lower against the oil pump. Try not to undo the 2 through the middle of the pulley, these clamp the 2 halves of the pump together, if you undo them it can release pressure off the gasket and compromise the seal.. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 24, 2014 Share Posted August 24, 2014 It's probs easier to take the ps pump carrier off completely.. So it's a handful of 14mm bolts.. One on back of pump, one onto block at bottom left front, and one on the aircon pump, and one a bit lower against the oil pump. Try not to undo the 2 through the middle of the pulley, these clamp the 2 halves of the pump together, if you undo them it can release pressure off the gasket and compromise the seal.. That is totally incorrect, sorry, the PAS pump mounting bolts have no effect whatsover on how the pump sections seal to one another. remove as you se fit, it won't cause or promote a leak. Quote Link to comment Share on other sites More sharing options...
Guest FullAttack Posted August 25, 2014 Share Posted August 25, 2014 That is totally incorrect, sorry, the PAS pump mounting bolts have no effect whatsover on how the pump sections seal to one another. remove as you se fit, it won't cause or promote a leak. We'll have to agree to disagree on that one. Iv had a couple that have started to seep from the copper gasket after disturbing those 2 bolts. They are usually haggered old pumps on driftcars though so work harder than the average pump;) Quote Link to comment Share on other sites More sharing options...
Ian C Posted August 25, 2014 Share Posted August 25, 2014 Mm I have to say I undid the wrong bolts on my PAS pump once and it spurted fluid everywhere, I've even got it on video. Easy mistake to make (that's my excuse anyway ) Quote Link to comment Share on other sites More sharing options...
Scooter Posted August 25, 2014 Share Posted August 25, 2014 I did mine by removing the aircon compressor and didn't touch the power steering.....just as a bit of additional info in case your leaking switch is an original 27mm one. "I had to change mine not too long back. Best thing to do is to get stuck in. When I changed mine, I found that Toyota had altered the design of the new switch and you need a smaller socket for the new one (24mm), had to go out and buy another long reach socket (27mm)." Quote Link to comment Share on other sites More sharing options...
Tommyd16 Posted September 3, 2014 Author Share Posted September 3, 2014 Changed it today. Had to take the ac compressor off. No way of getting a socket on there without taking the ac pump off Quote Link to comment Share on other sites More sharing options...
