SupraRider Posted August 23, 2014 Share Posted August 23, 2014 hi people, need some advice here..what are the offsets for the rear wheels on a JDL bodykit? im planning to buy a set of 19s with low profile tyres. front wheel size should be: r19/235? grateful for some help. thanks. Link to comment Share on other sites More sharing options...
listy Posted August 23, 2014 Share Posted August 23, 2014 How much wider than stock are the arches? What width of wheel are you looking at? (Wheel size, not tyre size) ie: stock body rear - 10" wide on a +35 offset will fit nigh on flush with the rear arches. So if you are looking at a 10" wheel, we need to know the EXTRA width on the arches (ie. 15mm wider than stock each side) to work out what your new offset needs to be. Also, only my opinion, but I wouldn't go for wheels any bigger than 18's, as the handling and ride are affected for the worse (imo) the bigger wheel (therefore smallet tyre wall size) you get. Link to comment Share on other sites More sharing options...
