dr_jekyll Posted August 23, 2014 Share Posted August 23, 2014 is there any benefit or evan can you run a small amount of meth without the car being mapped for it ? my trail of thought that the meth causes a cooler burn from what ive gathered so would adding a small amount of meth be good fo the engine if I was doing prolonged runs on track? or would it do nothing? Quote Link to comment Share on other sites More sharing options...
bignum Posted August 23, 2014 Share Posted August 23, 2014 It would certainly offer a safety net and there`s no harm in adding a system, i installed mine just incase i put some crap fuel in without knowing. Quote Link to comment Share on other sites More sharing options...
mellonman Posted August 23, 2014 Share Posted August 23, 2014 With no map in place to accommodate the slower burn you will just loose power as meth does not burn as well as petrol, but as a safety thing for det its good I believe, plus you need alot more meth vs petrol say you need twice as much straight meth injected as you do petrol or its something like that, Quote Link to comment Share on other sites More sharing options...
mellonman Posted August 23, 2014 Share Posted August 23, 2014 Harm side of things Make sure your fuel pump can run it as ethonal destroys pumps im not sure about meth though Quote Link to comment Share on other sites More sharing options...
The Raven Posted August 23, 2014 Share Posted August 23, 2014 Meth is bad. Ask walter white Quote Link to comment Share on other sites More sharing options...
Lee P Posted August 23, 2014 Share Posted August 23, 2014 You can get away with about 10% max but that's it and will be fine Quote Link to comment Share on other sites More sharing options...
bignum Posted August 23, 2014 Share Posted August 23, 2014 Meth is bad. Ask walter white Lol b/b Quote Link to comment Share on other sites More sharing options...
