Guest lloydy Posted August 19, 2014 Share Posted August 19, 2014 So decided id swap the green ignition ring for an led equivelent, ive done this before on previous cars no problems. took it all apart and was fine pull the bulb out replaced with an led version, it lit up and seemed fine, then in the process of putting it back together it has stopped working, i have checked the fuses and can find any that are blown, i have tested the the connector and it seems there is no power to the connector that is further back in the dash, everything else appears to be working correctly. so im abit stumped as to what has happened :/ if anyone could shed any light, or suggest anything id be grateful i checked the fuses in the engine bay and the drivers kick plate many thanks lloydy Quote Link to comment Share on other sites More sharing options...
