engine swap facelift/pre facelift
natony
I recently bought a cheap supra with a deceased engine, i already have an engine i took out of my old facelift
Will it be a straight swap ? (NA for NA) as one thing i noticed is that the pre facelift has an oil level sensor and the facelift doesn't
I fitted a facelift engine to my prefacelift Supra (NA). The only difference notable was the facelift engine not being fitted with an oil level sensor and the facelift engine loom obviously not having the connector for an oil level sensor even if you were to retrofit one. Be aware that this will flag up the large warning triangle light along with the yellow oil level caution light as the car will think you have low oil level.
