little num Posted August 19, 2014 Share Posted August 19, 2014 Right just a little about the car. Its a 1JZ that's had a lot of work done to it ( engine spec below ) and its bolted to a R154 gearbox with a brand new ACT 6 puk extreme clutch rated to 630flb. Its using a stock non turbo slipper diff and hold down the power with Federal FZ201 285-30-18 tyres, great tyres once warm. ENGINE SPEC 1JZ-GTE Fully rebuilt using CP pistons - TOMEI rods - ACL bearings - ARP bolts through out. Brand new oil pump fitted when engine was built. HEAD The head has had work done on the exhaust side to help the gas's escape quicker. Its got uprated springs and HKS 264 cams. BOLT ON PARTS Turbo is a BorgWarner s300 with billet wheel from AET turbo's in Normanton, very helpful and know what they are on about. Manifold is a 6 boost (read about them if you've never heard of them) amazing quality and have had some great results, even the titan supra used or still use's the same manifold. http://www.6boost.co.uk/ Wastegate I went with the turbosmart 45mm and it works a perfect with no boost spike or creep. Stock inlet manifold and wasent causing any problems from what we could tell. Whifbitz front mount intercooler kit ( here ) http://www.garagewhifbitz.co.uk/toyota/supra/intercoolers/garage-whifbitz-1230.html real nice bit of kit, airtemps were great, run after run never went above 30, but I have fully ducted it off so all the air the bumper catches is forced through it. Radiator is a fluidine with new Toyota viscous coupling Exhaust is TENABE MEDALLION and was flowing lovely, I do have a exhaust flap that is controlled from inside the car and once opened the exhaust gas's are diverted to a separate exhaust that's a lot louder and sounds the nuts when on boost, screamer pipe is diverted back into the downpipe as trackdays are noise limited usually to 98dbs. FUELING This is what let the the car down slightly as im running a bosch 044 intank pump with stock lines, im upgrading to twin 044's I think with a -8 fuel line feeding my rail. Also running a HKS twin spark ignition add on BUT my old coils are crap so will be buying some supersparks for when it goes back for a quick tune after the new parts are fitted. ECU is a HKS gold version 2, not as good as the syvecs but runs the engine great, I wouldn't use hardly any of the features the syvecs offer so don't see the point in having 1 just at the moment. Well here is what you wanted to see the mapping results, all the results are at the fly. The 683 was at 1.9 bar and was just running out of fueling as the 044 is maxed out at that, but was still safe BUT not running it at that lever until I upgrade the fuel system, this run was just to see exactly what it will do on the setup I have. Then Greg at Protuner (Redditch) started to find a happy HP that is ultra safe as he knows I don't hold back We found a max setting at 1.7bar and that was 653bhp but didn't log that run for some reason. The second run on the sheet is at 1.6bar with still a healthy 636bhp and with the boost controller set at 1.2 my lowest setting still made 559bhp, but I must admit it scares the crap out of me, but ill soon get used to it then want more lol. Link to comment Share on other sites More sharing options...
little num Posted August 19, 2014 Author Share Posted August 19, 2014 Oh the wiggle as it comes on full boost is it riding up on the rollers. Link to comment Share on other sites More sharing options...
ManwithSupra Posted August 19, 2014 Share Posted August 19, 2014 Nice results dude 600bhp is additive isn't it. I will also be in the high 600's hopefully soon. How are are the FZ201's I was looking at them for an alternative to R888's as I can get them at trade price. Link to comment Share on other sites More sharing options...
Shane Posted August 19, 2014 Share Posted August 19, 2014 Nice results James, well done and so nice to see something done a bit different to the rest. Link to comment Share on other sites More sharing options...
abtin90 Posted August 19, 2014 Share Posted August 19, 2014 Wow that's an awesome result. Congrats. Get some pictures of the car and bay up too Link to comment Share on other sites More sharing options...
Callaway Motorsport Posted August 19, 2014 Share Posted August 19, 2014 Pretty good results with that spec. Link to comment Share on other sites More sharing options...
Abz Posted August 19, 2014 Share Posted August 19, 2014 Nice!! Was you running this power on DB? As it was VERY quick... pretty sure my mate got a clip of you nearly eating MarcP's bumper Link to comment Share on other sites More sharing options...
mclarenross Posted August 19, 2014 Share Posted August 19, 2014 Great numbers! mine is a similarish spec and 1jz, what size injectors are you using? Link to comment Share on other sites More sharing options...
Pete Posted August 19, 2014 Share Posted August 19, 2014 Wow - great figures. Nice one. Link to comment Share on other sites More sharing options...
j_jza80 Posted August 19, 2014 Share Posted August 19, 2014 Video please tuned 1jzs sound incredible, more like an RB26 than a 2jz. Often toyed with the idea of building a 6 speed 1jz vvti, and tuning it to around 500hp for a savage road car with half decent economy. Link to comment Share on other sites More sharing options...
JamieP Posted August 19, 2014 Share Posted August 19, 2014 That's a great result James. Nice graph. Link to comment Share on other sites More sharing options...
bignum Posted August 19, 2014 Share Posted August 19, 2014 I drove it last night, drives really nice, progressive power which is a massive improvement over the old turbo. Link to comment Share on other sites More sharing options...
little num Posted August 19, 2014 Author Share Posted August 19, 2014 Cheers guys, I must admit its quite nippy, here are a few pictures I took while do the build. Im not 1 for taking loads of pictures, mostly because im that focused on getting the job done I forget to take pics. Link to comment Share on other sites More sharing options...
bignum Posted August 19, 2014 Share Posted August 19, 2014 Its a real track weapon now, i`m quite looking forward to racing it/you:cool: Link to comment Share on other sites More sharing options...
Chris Bailey Posted August 19, 2014 Share Posted August 19, 2014 Nice results! Your car was shifting on Dragonball Did you struggle with grip on the dyno? Link to comment Share on other sites More sharing options...
little num Posted August 19, 2014 Author Share Posted August 19, 2014 Nice results! Your car was shifting on Dragonball Did you struggle with grip on the dyno? Not really but my tyres are really good, and once hot they were sticking to the rollers nice, on dragonball it was probably 460hp and the turbo was getting smokey on let off as you might have seen, but ill have to take my sticker off the bumper now, NO SMOKE NO POKE as it now don't smoke lol. I might be going to the meet this sunday but ill see what else I have planned. Link to comment Share on other sites More sharing options...
Swampy442 Posted August 19, 2014 Share Posted August 19, 2014 Nice results James lad, really nice Link to comment Share on other sites More sharing options...
chazuk Posted August 19, 2014 Share Posted August 19, 2014 nice figures mate I look forward to seeing the track video Link to comment Share on other sites More sharing options...
a98pmalcolm Posted August 19, 2014 Share Posted August 19, 2014 Nice... Link to comment Share on other sites More sharing options...
Luxluc Posted August 19, 2014 Share Posted August 19, 2014 Wow. Congrats James. That must feel quick. What max power is the R154 rated? Link to comment Share on other sites More sharing options...
SteveR Posted August 19, 2014 Share Posted August 19, 2014 Mental I've got a used 044 I bought off Mr Whiffin ages ago but never fitted - yours if you want to collect it mate. I think I'm going to end up getting something else (fuel pump, not car!), whenever I get round to it... Link to comment Share on other sites More sharing options...
Josh Posted August 19, 2014 Share Posted August 19, 2014 Great results! In for the video Link to comment Share on other sites More sharing options...
trebor69 Posted August 19, 2014 Share Posted August 19, 2014 Thats an awful lot of bhp dude .... Link to comment Share on other sites More sharing options...
little num Posted August 19, 2014 Author Share Posted August 19, 2014 Mental I've got a used 044 I bought off Mr Whiffin ages ago but never fitted - yours if you want to collect it mate. I think I'm going to end up getting something else (fuel pump, not car!), whenever I get round to it... Cheers mate I might very well take you up on the offer, not bad results from a baby jz family. Link to comment Share on other sites More sharing options...
