Mcdade Posted August 18, 2014 Share Posted August 18, 2014 What alloy radiators would you guys suggest?? Link to comment Share on other sites More sharing options...
mplavery Posted August 18, 2014 Share Posted August 18, 2014 SRD or Whifbitz one mate Link to comment Share on other sites More sharing options...
Mcdade Posted August 18, 2014 Author Share Posted August 18, 2014 Cheers man. Al have a look. Link to comment Share on other sites More sharing options...
The-Plethora Posted August 19, 2014 Share Posted August 19, 2014 Fastrads in newport seem to get quoted a bit too, supposed to be really cheap but good quality, a few members have tried them now. Link to comment Share on other sites More sharing options...
Mcdade Posted August 19, 2014 Author Share Posted August 19, 2014 Cheers i will have alook online at fastrads too. Link to comment Share on other sites More sharing options...
ripped_fear Posted August 19, 2014 Share Posted August 19, 2014 What power are you running, personally I would suggest a brand new OEM Link to comment Share on other sites More sharing options...
Guigsy Posted August 19, 2014 Share Posted August 19, 2014 Me 2. Chris Wilson always has interesting things to say about alloy vs stock rads. But I bet he is tired of repeating himself. Link to comment Share on other sites More sharing options...
Dnk Posted August 19, 2014 Share Posted August 19, 2014 Stock rad has probably the best core but not bling enough, are most of the aluminium ones from China ? Link to comment Share on other sites More sharing options...
Mcdade Posted August 27, 2014 Author Share Posted August 27, 2014 Only bpu power atm, so stock is better?, reason i ask is that this is my first supra/jap car so on a bit of a learning curve here lol. Link to comment Share on other sites More sharing options...
Dnk Posted August 27, 2014 Share Posted August 27, 2014 Only bpu power atm, so stock is better?, reason i ask is that this is my first supra/jap car so on a bit of a learning curve here lol. Pretty sure a new OE radiator will be just as good if not better than many of these supposed uprated aluminium ones. A few members with singles run them as far as i'm aware with no problems My car was 400 ish hp and no issues with stock set up, i had a new rad, new heater matrix and thermostat on my car though, all OE Link to comment Share on other sites More sharing options...
Nic Posted August 27, 2014 Share Posted August 27, 2014 (edited) The only problem with the stock rad is that the plastic tanks can become brittle over time and break/crack, especially if using an aluminium upper rad hose. I'd normally recommend the Power Enterprise double core aluminium radiators unfortunately they are now discontinued. I've never used them but Mishimoto seem to have a good reputation for making quality aluminium radiators http://www.mishimoto.co.uk/toyota-radiator-performance-aluminum.html Edited August 27, 2014 by Nic (see edit history) Link to comment Share on other sites More sharing options...
Dnk Posted August 27, 2014 Share Posted August 27, 2014 If i had a supra now with its original rad it would be in the bin no matter what hp i was running to be honest Link to comment Share on other sites More sharing options...
jazz1 Posted August 27, 2014 Share Posted August 27, 2014 I beleive the original Rad is prone to crack over time mine did, I'm pretty use these alloy ones won't? Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 27, 2014 Share Posted August 27, 2014 The top tank pipe stub on stock rads usually crack because people unthinkingly fit alloy or polished top hoses. The engine moves *CONSIDERABLY* side to side on its mountings when there is torque reversal, the stock top hose just flexes. fit a virtually solid top hose with just short, very stiff, joiner pipes, and the rad is being asked to control engine movement. Needless to say it doesn't enjoy this newly found job. The two aftermarket rads I had checked were inferior to a new stock rad. Link to comment Share on other sites More sharing options...
