JamieP Posted August 18, 2014 Share Posted August 18, 2014 Is there a list anywhere? Are facelift 6 speed small diff and pre facelift 6 speed big case the same ratio? Quote Link to comment Share on other sites More sharing options...
Chris88 Posted August 18, 2014 Share Posted August 18, 2014 Is there a list anywhere? Are facelift 6 speed small diff and pre facelift 6 speed big case the same ratio? http://mkiv.supras.org.nz/specs.htm Quote Link to comment Share on other sites More sharing options...
Homer Posted August 18, 2014 Share Posted August 18, 2014 To answer your question directly Jamie, Yes, they are both 3.266 on the jspec cars. Euro cars had a different ratio which is not documented on the NZ site. Quote Link to comment Share on other sites More sharing options...
JamieP Posted August 18, 2014 Author Share Posted August 18, 2014 Thanks. Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted August 18, 2014 Share Posted August 18, 2014 The gear ratio calculator lists the various diff ratios: http://www.mkivsupra.net/vbb/showthread.php?225050-Supra-specific-gear-diff-ratio-and-tyre-size-calculator Quote Link to comment Share on other sites More sharing options...
Littler Posted August 18, 2014 Share Posted August 18, 2014 Yep both small case are the same, it's the uk 6 speed big diff that's different at 3.133 Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted August 19, 2014 Share Posted August 19, 2014 Yep both small case are the same, it's the uk 6 speed big diff that's different at 3.133 Only diff with3.13 is the US spec 6speed. Here is an overview of the different diffs with ratios; http://www.mkiv.de/artikel/allgemein/differentiale/ Edit: English version of the table http://www.supra-forum.com/articles/general/differentials/ Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted August 19, 2014 Share Posted August 19, 2014 Only diff with3.13 is the US spec 6speed. Here is an overview of the different diffs with ratios; http://www.mkiv.de/artikel/allgemein/differentiale/ Edit: English version of the table http://www.supra-forum.com/articles/general/differentials/ They don't list the UK spec on there, which is different to the other cars in quite a few ways, so it's possible that the UK uses the same diff ratio as the US spec. It would be interesting to find out where Homer got the indo from when he made the gearing calculator. Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted August 19, 2014 Share Posted August 19, 2014 They don't list the UK spec on there, which is different to the other cars in quite a few ways, so it's possible that the UK uses the same diff ratio as the US spec. It would be interesting to find out where Homer got the indo from when he made the gearing calculator. Had a look on Toyodiy.com and confirmed my post above... the UK Spec 6Sp RHD JZA80R-AJFVZW(aerotop) has the same Part Number as the EU Spec stated in my links. Namely: 41201-80055 FINAL GEAR RATIO=49:15=3.267 The Second RHD 6SP i've found JZA80R-ALFVZW(Hardtop) has the same number and comment: 41201-80055 FINAL GEAR RATIO=49:15=3.267 Honestly i couldn't think of that much differences between the UK Spec TT and the EU Spec TT except the Steering wheel and some other minor changes(Headlight Sprays etc). Technically they are the same AFAIK. Quote Link to comment Share on other sites More sharing options...
JamieP Posted August 19, 2014 Author Share Posted August 19, 2014 There is no such thing as a UK aerotop. Quote Link to comment Share on other sites More sharing options...
CanisLupus Posted August 19, 2014 Share Posted August 19, 2014 Was wondering too... Don't know where a rhd Euro modell with aerotop and 6sp was sold if ever has been? Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted August 19, 2014 Share Posted August 19, 2014 There were no factory RHD Turbo 6 speed Aerotops. The only RHD manual Aerotops are a rumoured few NAs, but I'm yet to see one. Quote Link to comment Share on other sites More sharing options...
