Seven row oil cooler and relocation kit
uzzyuzzy
Ive just relocated my filter to where the ABS pump sits, however i made up my own lines and bought a cooler and relocation parts seperatly.
If you go down that route tho i would recomend you buy an oilstat to control the oil temps as its recomended that the oil is around 80/85*C to prevent engine wear.
Also make sure your filter has a non return valve built in to stop the oil flowing out of the filter and lines when the car is not in use :)
