Electrical issue.
antno
Hello
My car is a 96 tt6 jspec
I've got a problem with my charging system. I thought it was just an alternator so I have ordered a new one from mr t. The alternators not due in till end of sept so I bought a second hand one to get me about until then.
The second hand one turned out to be one off an auto so it was a bit bigger and the connectors were in a slightly different place. I got her fitted but when it started I heard some electrical arching.
Stripped it down and it looked like it was getting hot around the rectifier. Some of the paint had melted.
So I stripped my original one down and again I found the rectifier burnt out
I had been driving with this till the dash lights lit up.
I checked the terminals that connect to the alternator and the main battery feed (b) was live. The white wire to the regulator was live (12.5v). The yellow wire was to ground. And the yellow and green wasn't connected to earth or live. This was all with the ignition switched off. Also the alternator body was earthed and had a resistance of 3.4 ohms.
With ignition on all three reg wires became live. The White was 12.5v the others were 12.0v
My questions are.
Should that yellow wire be grounded when the ignition is off?
Also had anyone else had rectifiers burn out?
Cheers antno
Sorry I double checked the alternator body to earth this morning and it is 0.4 ohm but when the ignition is switched on it goes up to 7.6ohms. Is this normal? This was all on a cold engine with no wires connected to the alternator.
Do you think a bad earth could fry the rectifie?
No it should not go up. if you have some jump leads connect the negative lead to the battery NEG and the other end to the engine block somewhere and recheck resistance that will confirm if you have a bad earth. poor connections increase load so its possible to burn diodes
