Ibrar Jabbar Posted August 16, 2014 Share Posted August 16, 2014 Engine Type - 2JZ GTE VVTi Single Turbo Engine Spec - ARP Head Studs ARP Rod Bolts ARP Main Bolts Clevite bearings Forged Wiseco pistons Forged EagleRods 1.2mm HKS headgasket Titan crank damper pulley Unorthdox racing pulleys Titan cam pulley (EXH) HKS 264 race cams (EXH) TRD thermostat HKS Timing belt Tial 50mm BOV 5” ETS Front mount Intercooler 1000cc Injector Dynamics injectors Hypertune inlet manifold 90mm Corvette LS7 DBW throttle body Turbo - Borg Warner S300 91-79 Fuel Used - Shell V-Power Exhaust - (4" Custom) Transmission - (V161) ECU - (Syvecs) Mapped By - Ryan G Dyno Used - AME @ Silverstone Power figure - 727 Hub hp Torque figure - 664 lbft Boost Pressure - () http://mkivsupra.net/vbb/attachment.php?attachmentid=153718&d=13402289949 Link to comment Share on other sites More sharing options...
JamieP Posted August 16, 2014 Share Posted August 16, 2014 Serious dyno graph, I bet that's good fun to drive, I want the same from mine. Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted August 16, 2014 Author Share Posted August 16, 2014 It is Jamie, however I feel acceleration in first gear is a little slow. Link to comment Share on other sites More sharing options...
JamieP Posted August 16, 2014 Share Posted August 16, 2014 Surprised at that, does it make full boost in first? What is traction like? Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted August 16, 2014 Author Share Posted August 16, 2014 Spins up 1st and 2nd with traction off (on hard acceleration). I'm sure its making full boost but now you have mentioned it, I will double check. Hopefully Pod will go ahead and we can compare. Link to comment Share on other sites More sharing options...
j_jza80 Posted August 16, 2014 Share Posted August 16, 2014 What diff are you running? Link to comment Share on other sites More sharing options...
Luxluc Posted August 17, 2014 Share Posted August 17, 2014 Ryan often limits boost in first gear. He did so on mine. Link to comment Share on other sites More sharing options...
