I broke my car
Slam
I still can't get my head around how the belt jumped from the outer ring when it separated to then land on the crank again
Exactly the same thing happened to me!! It happened in the middle of the night and I was about 1.5 miles from home so carried on driving home slowly as I couldn't work out what happened apart from losing power steering.
Imagine my horror when I saw the crank pulley on the engine tray and belt intact like you :D
Has anyone tired doing it like in this video .
Yes I have done it.
Works like a charm, but support the wrench real good so it don't come flying around and hit something
Maybe wrench is the wrong word for the took as my english is way off, the tool I used is the same as in the video with a socket on it
Don't forget, once the bolt is out you're going to need a way to get the leftover part of the pulley off the crank. Would be best (easiest) done with a puller.
Yer saw that bit in the video clip, might just pop it into local garage.
Alot of Guys use Tipex to mark the front of the pulley so you can see when the outer ring starts to move and replace it before it flys off !
Usually buying second hand is false economy you re swapping an old part for another old part when the rubber has started to perish, I bought a genuine one off Ebay USA £125 including custom charges and delivery.
