1000+ BHP Exedy Carbon-R triple plate clutch
JamieP
Jamie, sorry to hijack, but did you have any issues with your previous HKS LA clutch?? had mine fitted for less than a thousand miles, and yesterday the pedal went solid. Slave cylinder is fine. I used all new Toyota supporting parts on the install. Also my LA twin plate rattles like hell, and apparently they are supposed to relevantly quiet clutch. Have you heard or had any of these issues previously your self??
Sorry again for the hijack bud, Steve.
Haven't heard anything from them yet. They planned to remove the box Friday. I'm in work this weekend, so will pop up there on Monday and hopefully it will be done. Hoping it's a problem with the thrust bearing and not the clutch itself. I'll post up the outcome.
  • 2 weeks later...
Box is now out of the car. The centre pull ring/bearing has pulled away from the LA's pressure plate :(. It just slides away from clutch during clutch fork operation, instead of the usual pull/release function.
Not sure if I need a replacement LA pressure plate, or just a new Toyota release bearing TBH??
  • 1 year later...
just fitted mine and i it rattles too......don't know if its normal or not as i never had a twin plate before..its not a quite clutch.Also sometimes rattle when the car is free without pressed clutch pedal
I've got an exedy twin plate and mine rattles also, I have a lightened flywheel which is what causes the rattle, I imagine yours is the same. Completely normal dude
