supra_24 Posted August 16, 2014 Share Posted August 16, 2014 Hey guys, Got around to sorting the previous issues with my new supra, but now some other strange noises have appeared. So thought you ma be able to help advise me on them? The first noise is like a light blowing noise from under the bonnet when moving on off drive way. Sounds like when air escapes slightly from a balloon on occasion. The second noise is a rattle which is more prominent on startup. Sounds as if it comes from underneath the car just before the front wheels. The rattle isn't too loud and does settle down a bit after warming up, but you hear it a bit more if you tap on off the revs. Any help on this would be greatly appreciated, as all these issues are kinda causing me some uneeded stress atm. Thanks again. Regards Ash Quote Link to comment Share on other sites More sharing options...
Nic Posted August 16, 2014 Share Posted August 16, 2014 What Supra model? Quote Link to comment Share on other sites More sharing options...
supra_24 Posted August 16, 2014 Author Share Posted August 16, 2014 Its a na shell with a tt engine and 5 speed w58 with stage 3 clutch. Quote Link to comment Share on other sites More sharing options...
supraGZaerotop Posted August 16, 2014 Share Posted August 16, 2014 both my supras have done this, normally if its been parked up for a couple of days, strange sort of blow/rattle/ hasint dont it for ages, seems like it comes from the gearbox area to me, drive 20 yards down the road and it goes. i dont take any notice of it anymore because nobody seems to have an idea what it is? i did a post of it years ago with a vid and noise, have alook back throw my posts, way back tho Quote Link to comment Share on other sites More sharing options...
The Raven Posted August 16, 2014 Share Posted August 16, 2014 The rattle may well be the heat shield Quote Link to comment Share on other sites More sharing options...
supra_24 Posted August 16, 2014 Author Share Posted August 16, 2014 I was considering going back to whifbitz London on Monday, but it would be my second journey back there :/ The blowing noise isn't a major issue, but only just started noticing it. The rattle sometimes changes pitch in noise, so i becomes a bot more squeaky? Is anything major to worry about? Apart front this the noise stops after driving and turbod wotl as they should and generally dri es fine? Quote Link to comment Share on other sites More sharing options...
supra_24 Posted August 16, 2014 Author Share Posted August 16, 2014 Any other suggestions guys on these issues? Cheers Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 16, 2014 Share Posted August 16, 2014 If you are not good at handling stress I would say a W58 behind a TT engine is perhaps not for you The `box is now well over its design torque limit and they are a bit like a grenade behind a TT. Whatever a Stage whatever clutch might mean, I don't know, but if it's grabby and fierce it will potentially put even greater shock loadings through the `box, so treat the thing with kid gloves, no hard standing starts, no snatchy gear changes. The W58 is known for layshaft bearing noise at the best of times, does some of the noise go when you depress the clutch in neutral, engine idling? Quote Link to comment Share on other sites More sharing options...
supra_24 Posted August 16, 2014 Author Share Posted August 16, 2014 Ok cheers mate. When i say stress its juts that i have a lot going on atm what with jobs etc.. When it comes to cars im usually pretty good with sorting them. I had a s15 at one stage, so no stranger to imports lol. Its just that the supra is new to me and trying to get rid of all the noises lol. In regards to the rattle, i believe it goes away after warming up/driving for a while. Not sure about when i depress the clutch. Just wanted to try and figure out the issue so i can sort it bud Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 16, 2014 Share Posted August 16, 2014 Jsut try pressing the clutch to the floor in neutral and see if the noise goes, if it goes then it's bearings inside the gearbox, probably layshaft or first motion shaft bearings Quote Link to comment Share on other sites More sharing options...
supra_24 Posted August 16, 2014 Author Share Posted August 16, 2014 is it something problematic that i would need to resolve soon or can i just live with it? Regards Ash Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 16, 2014 Share Posted August 16, 2014 I would find out just what it is, until we know that it's impossible to say what the longer term consequences of ignoring it may be. Quote Link to comment Share on other sites More sharing options...
listy Posted August 16, 2014 Share Posted August 16, 2014 is it something problematic that i would need to resolve soon or can i just live with it? Regards Ash If it's as Chris says, then yes, you can live with it......until the gearbox completely poops itself, like mine did not long ago (same set up) If the noise goes when the clutch is depressed, start looking for a new gearbox, is my advice. Quote Link to comment Share on other sites More sharing options...
supra_24 Posted August 16, 2014 Author Share Posted August 16, 2014 From recollection it still occurred when depressed. However i will double check when i go out to my car after work at 6pm. Quote Link to comment Share on other sites More sharing options...
supra_24 Posted August 16, 2014 Author Share Posted August 16, 2014 Ok guys. Quick update. Just started car up after working with the rattling noise and depressed clutch. The noise continued, so i would assume its not anything to do with my clutch. Anything else it could be? Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 16, 2014 Share Posted August 16, 2014 You need to get it up on a ramp and have a proper poke about whilst it's doing this, it could be almost anything. You could run it for a minute or two *ONLY* with the auxiliary belt off and see if the noise is gone. If it has gone then it's something the auxiliary belt drives, obviously. Carefully listening to areas with the handle of a long screwdriver to your ear may localise the source. It may also punch a hole in your skull if you poke into something that's moving Or you could just ignore the noises and wait and see if anything vital falls off, or makes itself blindingly obvious. Quote Link to comment Share on other sites More sharing options...
supra_24 Posted August 16, 2014 Author Share Posted August 16, 2014 May talk to whifbitz and see if they can look at it Monday. Its definitely not any of the belts or runners at the front of the engine as these have all just been replaced by whifbitz last week. I think it may be a hanger or exhaust rattle myself. Guess i will see what Darren says and get it looked at. She drives great apart from this. Really lovely car after 4 months of restoration. Quote Link to comment Share on other sites More sharing options...
