Luxluc Posted August 15, 2014 Share Posted August 15, 2014 (edited) Engine Type - Single Turbo was TT originally Engine Spec - Built Engine with Mahle 86.5mm pistons and Carillo Rods, SRD Stage 5 Head with 280 camshafts, GReddy intake manifold, HKS exhaust manifold with screamer pipe. Turbo - CEA 6766 1.00 A/R Twin Scroll. Fuel Used - Luxembourg V-Power (only 1% ethanol) / 50% ethanol Fuel setup- ASNU 1100 injectors, twin Walbro 485 pumps, Flex fuel kit with teflon lines Exhaust - 4" DP/MP with Whifbitz 4" Ti single box exhaust Transmission - V160 ECU - Syvecs Mapped By - 2barTuning Dyno Used - Abbey Hub Dyno Power figure - 756 rhhp on VPower / 840 rhhp on 50% ethanol Torque figure - 598 ftlbs on VPower / 703 ftlbs on 50% ethanol Boost Pressure - 1.7 bar on VPower (red curve) / 2bar on 50% ethanol (blue curve) The green curve was 1.7 bar on 50% ethanol, but with a lot more timing. Edited August 17, 2014 by Luxluc (see edit history) Quote Link to comment Share on other sites More sharing options...
thetrashcanman Posted August 17, 2014 Share Posted August 17, 2014 Beast! Quote Link to comment Share on other sites More sharing options...
GlennK Posted August 17, 2014 Share Posted August 17, 2014 Luc, great figures! How does the CEA compare to the S366 for spool up? Quote Link to comment Share on other sites More sharing options...
Luxluc Posted August 17, 2014 Author Share Posted August 17, 2014 (edited) Beast! :d Luc, great figures! How does the CEA compare to the S366 for spool up? The 6766 spools quicker than the S366 Glenn (even that the 6766 has a 1.00 AR housing, and my S366 was a 0.91 AR). It confirms what the yanks told me when I asked for advice. SP (Sound Performance) told me that the 6766 would spool a couple of 100 rpm quicker, plus push around 50 bhp and 50 tq more. I uploaded the BL setup in the dyno section too. You can compare. Edited August 17, 2014 by Luxluc (see edit history) Quote Link to comment Share on other sites More sharing options...
Kaan W Posted October 9, 2014 Share Posted October 9, 2014 (edited) That looks lively from 3.5k revs We're the injectors maxed out or could the 1100s go further? Edited October 9, 2014 by Kaan W (see edit history) Quote Link to comment Share on other sites More sharing options...
Luxluc Posted October 16, 2014 Author Share Posted October 16, 2014 That looks lively from 3.5k revs We're the injectors maxed out or could the 1100s go further? The injectors were approaching the limit mate. Ryan raised the base pressure to 4 bar / 60 psi. The injectors were at 89% DC on 52% ethanol. Quote Link to comment Share on other sites More sharing options...
Guest Dan ep3 turbo Posted March 22, 2015 Share Posted March 22, 2015 The injectors were approaching the limit mate. Ryan raised the base pressure to 4 bar / 60 psi. The injectors were at 89% DC on 52% ethanol. Nice results from a 67mm turbo, how different does the car feel to drive on the precision compared to the boost lab s366? You going to try a Borg Warner efr at all? Quote Link to comment Share on other sites More sharing options...
Luxluc Posted March 22, 2015 Author Share Posted March 22, 2015 Nice results from a 67mm turbo, how different does the car feel to drive on the precision compared to the boost lab s366? You going to try a Borg Warner efr at all? See post #4 mate. I won't try the BW EFR turbos .... but those Precision Gen2 turbos seem to be great. Quote Link to comment Share on other sites More sharing options...
Carbon_Bullet Posted March 22, 2015 Share Posted March 22, 2015 Interesting....... Quote Link to comment Share on other sites More sharing options...
Guest Dan ep3 turbo Posted March 22, 2015 Share Posted March 22, 2015 I no you said a couple of hundred rpm earlier but I wondered if it felt more of a difference under real life conditions rather than just duno runs? Are you not to over keen on the efr then? What have you done with your bl s366? Dan Quote Link to comment Share on other sites More sharing options...
Luxluc Posted March 22, 2015 Author Share Posted March 22, 2015 I no you said a couple of hundred rpm earlier but I wondered if it felt more of a difference under real life conditions rather than just duno runs? Are you not to over keen on the efr then? What have you done with your bl s366? Dan My old BL366 has been sold Dan. The 6766 feels a lot more agressive mate; those 700+ ftlbs are awesome. I see 1.4 bar @ 4000 rpm in 4th gear, 1.7 bar @ 4200 rpm. Quote Link to comment Share on other sites More sharing options...
Guest Dan ep3 turbo Posted March 22, 2015 Share Posted March 22, 2015 My old BL366 has been sold Dan. The 6766 feels a lot more agressive mate; those 700+ ftlbs are awesome. I see 1.4 bar @ 4000 rpm in 4th gear, 1.7 bar @ 4200 rpm. I would have been interested in that you got any other turbo you want to sell?seems you have tried a few different turbos? Didn't the bl make slightly more power and torque at slightly less boost? wish a 6766 would spoil like that on my rb26. Any reason you didn't go for a bb 6766? I no from the test sound performance have done the bb and jb pt are a lot closer performance wise than some would expect Quote Link to comment Share on other sites More sharing options...
Guest Dan ep3 turbo Posted March 22, 2015 Share Posted March 22, 2015 The boost lab made 9 hp less but 8 ftlb more but the bl was running 1.5 bar and precision 1.7? Quote Link to comment Share on other sites More sharing options...
Ibrar Jabbar Posted March 22, 2015 Share Posted March 22, 2015 Nice result Quote Link to comment Share on other sites More sharing options...
Luxluc Posted March 23, 2015 Author Share Posted March 23, 2015 The boost lab made 9 hp less but 8 ftlb more but the bl was running 1.5 bar and precision 1.7? pay attention mate. When the BL was dyno'ed, I had UK VPower Nitro in the tank. With the 6766, I had only crappy Luxembourg Shell V-Power in the tank (1% ethanol only). You can't really compare the 2 sheets Nice result Thanks Ibrar Quote Link to comment Share on other sites More sharing options...
Guest Dan ep3 turbo Posted March 23, 2015 Share Posted March 23, 2015 pay attention mate. When the BL was dyno'ed, I had UK VPower Nitro in the tank. With the 6766, I had only crappy Luxembourg Shell V-Power in the tank (1% ethanol only). You can't really compare the 2 sheets Thanks Ibrar My bad, I should have seen that Quote Link to comment Share on other sites More sharing options...
Luxluc Posted April 24, 2015 Author Share Posted April 24, 2015 A remap on E85 is planned within the next months ; I would like to see if Ryan can squeeze out a bit more out of that 6766 Quote Link to comment Share on other sites More sharing options...
TwinTurboM3 Posted December 17, 2016 Share Posted December 17, 2016 Bumping an old thread. What are the ignition values on V power pump gas @ 7000 and 8000 rpm and 1,7 bar? Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted December 17, 2016 Share Posted December 17, 2016 Luc doesn't have that turbo anymore Quote Link to comment Share on other sites More sharing options...
Luxluc Posted December 17, 2016 Author Share Posted December 17, 2016 Bumping an old thread. What are the ignition values on V power pump gas @ 7000 and 8000 rpm and 1,7 bar? Sorry mate. I cannot answer you on that as I replaced the turbo by a 6870 unit Quote Link to comment Share on other sites More sharing options...
Guest tomhank1511 Posted December 19, 2016 Share Posted December 19, 2016 I can not help you, sorry Quote Link to comment Share on other sites More sharing options...
