paulj1 Posted August 14, 2014 Share Posted August 14, 2014 Hi any one have an idiot's step by step guide to change the rear speakers in an 96 rz? I want to do mine before driving down to The Falcon on Sunday week. Cheers Paul Quote Link to comment Share on other sites More sharing options...
Dim Sum Posted August 14, 2014 Share Posted August 14, 2014 Just upgrading it and it be simple. Take cover off, unscrew three or four screws and unplug the two pins. Done Quote Link to comment Share on other sites More sharing options...
Abz Posted August 14, 2014 Share Posted August 14, 2014 Pretty much exactly as Dim Sum mentioned, the cover is very easy to take off with a butter knife or flat head. Then I remember mine had 4 screws and the usual two wires. Once you take off the cover you'll have a better understanding Quote Link to comment Share on other sites More sharing options...
David P Posted August 14, 2014 Share Posted August 14, 2014 Pretty much exactly as Dim Sum mentioned, the cover is very easy to take off with a butter knife or flat head. Then I remember mine had 4 screws and the usual two wires. Once you take off the cover you'll have a better understanding Refit with a rolling pin maybe? Quote Link to comment Share on other sites More sharing options...
Abz Posted August 14, 2014 Share Posted August 14, 2014 Refit using a rolling pin maybe? I like to use the first thing that catches my eye and it was the butter knife on the way out... with butter still on Quote Link to comment Share on other sites More sharing options...
David P Posted August 14, 2014 Share Posted August 14, 2014 I like to use the first thing that catches my eye and it was the butter knife on the way out... with butter still on Little wonder your missus hides those wellies? Quote Link to comment Share on other sites More sharing options...
Abz Posted August 14, 2014 Share Posted August 14, 2014 little wonder your missus hides those wellies? Quote Link to comment Share on other sites More sharing options...
paulj1 Posted August 14, 2014 Author Share Posted August 14, 2014 Brilliant cheers guys also is it 17 cm ones in the back and do they have to be shallow speakers or just normal ones? Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted August 14, 2014 Share Posted August 14, 2014 Brilliant cheers guys also is it 17 cm ones in the back and do they have to be shallow speakers or just normal ones? I have 17.5's in mine and they are not shallow, they fitted straight in, the only thing that may vary is if you have the oem GZ rear speaker pods. Quote Link to comment Share on other sites More sharing options...
brom86 Posted November 12, 2014 Share Posted November 12, 2014 I have briefly attempted to remove my rear speakers but it's too wet and dark to keep trying. I have removed the 4 screws from the drivers rear speaker but the speak isn't moving at all. It's like stuck. Do I need to give it a real good pull or do anything else? Quote Link to comment Share on other sites More sharing options...
Al Massey Posted November 12, 2014 Share Posted November 12, 2014 I have briefly attempted to remove my rear speakers but it's too wet and dark to keep trying. I have removed the 4 screws from the drivers rear speaker but the speak isn't moving at all. It's like stuck. Do I need to give it a real good pull or do anything else? There is a bit of glue holding it in place. Just pry it off and all will be fine Quote Link to comment Share on other sites More sharing options...
keron Posted November 12, 2014 Share Posted November 12, 2014 you will need a flathead screwdriver (or crowbar!!!) or something to pry it off.... they are held on very very well! Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted November 12, 2014 Share Posted November 12, 2014 As above they have a glue on them too, then require a fair bit of force. I destroyed my speakers getting them out, bent a fair bit, but luckily they were destined for the bin anyway. Quote Link to comment Share on other sites More sharing options...
brom86 Posted November 12, 2014 Share Posted November 12, 2014 Aw great cheers lads, a thought the thread title was perfect for me as I couldn't see why they weren't budging haha. I'll get a flat head into it tomorrow morning. Quote Link to comment Share on other sites More sharing options...
