no maf sensor? help
Guest Pricer69
Guest Pricer69
hey guys the 1995 supra non turbo has been running abit sluggish lately and rubbish on fuel.. i average like 240 on £60.. double decat, i dont know if any of you guys have the same or not?
also a friend of mine said to clean out the maf sensor but i literally dont have one :/ lol
all i got is the air temp sensor
hope one of you out there could help me out
cheers
Edited by Pricer69 (see edit history)
The none VVTi N/A is an RPM / Throttle angle based system, no mass air flow sensor used.
I would get rid of that none stock air filter set up, and fit the original air box and filter. The N/A has a well designed
pulse tuned inlet system that uses resonances in the intake tract to aid cylinder filling. Going none stock on the intake
often reduces performance and increases fuel consumption significantly.
I think the phrase is "p***ing in the wind"
Guest Pricer69
cheers for the replies guys :) a friend of mine id say that a mushroom filter is the worst thing u can put on a NA car lol, already brought the car like that but will deffo change it to the stock :)
Decatting is fine, there's been (incorrect) talk of N/A's needing exhaust back pressure on here. No piston engine likes back pressure.
What they do like is an intake and exhaust system designed to maximize cylinder scavenging by being resonant at critical places in the
torque curve. De-catting will gain a modicum of power, nothing dramatic though. Here's something I wrote years ago concerning tuning N/A engines:
The following general stuff in regard to tuning
late,fuel injected,electronically managed engines may help.
Post the early eighties,more and more manufacturers went to electronic
management of ignition and fuel,via fuel injection,and mapped ignition
systems. Most fuel injection systems had one immediate impact. They no
longer need a restrictive venturi (narrow throat) in the carburettor
(s) to pull fuel out of the fuel bowl of the carb. Fuel injection
*injected* the fuel under high or very high pressure. No restriction as
such,and hence less of a power loss. Management of the ignition and
fuel suddenly meant engines could get away with running camshafts with
greater overlap,and higher lift,too. The old advance weight disi,and
velocity sensitive carb limited what cam profile could remain
driveable, without hesitations,poor low end performance and flat
spots. To a large extent electronic management allowed much more
freedom in valve sizes,port shapes,and cam timing,as well as running
the engine at the best amount of ignition advance at all loads and
RPM's without detonation,on differing fuel qualities,via knock sensor
technology.
What I am slowly getting at is that it is *much* harder to get
anything like a useful power gain from a modern,well designed,16 valve
production engine on electronic management. The exhausts are free
flowing,as are the intake systems. One needs to look at further
performance optimisation of the cam profiles,and maybe bigger
valves,stronger valve springs,moves away from hydraulic valve lifters
and mechanical improvements to make higher revs safe,from a
mechanical stress related point of view. Almost any change that has the
potential for a marked improvement in power and torque,will require
different fuel curves (the amount of fuel injected at any one set of
parameters of air flow,temperature,engine RPM etcetera,etcetera),and
different timing curves. One can fudge the fuel,*across the whole
curve*,by increasing fuel pressure via an "up rated" fuel pressure
regulator,but the the weeks of dyno testing to get the fuelling
correct at every point,has then gone to pot ... :-(
As for the ignition, the *correct* answer is an
aftermarket injection system,or at least an aftermarket ECU and
wiring,that allows one to map the curves afresh,to suit your new power
modifications. This is expensive,both in terms of hardware,(maybe over
£1000 for the ECU and wiring loom),plus a lot of professional engine
dyno time to get it all mapped correctly.
Sometimes one can buy a complete package,say new cams,different
throttle bodies and manifold,etcetera,that can come complete either
with a modified EPROM for the existing ECU,or an aftermarket mappable
ECU complete. If one limits mods to exactly those which the kit
manufacturer intended,this should work well. If you change any
parameter from the tuners package,the early comments about incorrect
curves again apply..
Changing the exhaust *system* or the air filter,on 90% of modern
engines will do sod all.The mags claim this and that,but in reality a
gain of 5 HP on a 120 HP engine is neither here nor there,for a road
car. Humidity variations can see that much change. A rolling road is
hard pressed to accurately repeat to 5 BHP on a figure of 120 HP
total. To get greater gains,say 20 HP,you need to look at fairly
dramatic alterations,both to the mechanical components,and their
related fuelling and ignition curves.
Turbo engines are a slightly different kettle of fish,as it is trivial
to raise the boost,and usually to fudge some additional fuelling.
Naturally aspirated remain tricky!
The easiest/cheapest way to see increased performance is to reduce
the weight of what the engine is driving, or its own rotating parts.
Especially rotating weight,for improved acceleration. Do most
people ask the most important question when buying new wheels,after
ensuring the offset and sizing is correct? Do they *uggery :-) They
should take a fishermans scales with them,and weigh the damned
things. The first question a race car manufacturer asks his potential
wheel suppliers is what do they weigh,and what is their rotational
inertia. Simple questions,and the weight,if not rotational inertia,is
easily self assessed performance differences can be
surprising,and worthwhile. Given 3 different makes of tyre,with similar
grip and handling characteristics,go for the lightest..Just weigh some
of the cheap imported tyres against a decent performance make,like a
Hoosier competition tyre that is road legal. The difference is
amazing. As for remolds,they are incredibly heavy.
If you are serious,and can live without goodies,buy a car with the
minimum spec. Sun roofs,air con,PAS,electric windows and mirrors,power
seats all can add hundreds of pounds. Lightweight front seats can add
as much performance,in real terms,as a new exhaust and manifold. 40
pounds of fancy stereo gear does nothing for performance ;-)
As cars become better,and more highly developed,the art of tuning
their engines becomes more complex and expensive,unless one looks at
the situation with a bit of lateral thinking. Instead of adding
things,think in terms of removing them. Instead of buying a new set of
wheels just for their looks,weigh them,and see if a gain can be had
for free there.
Just ideas,some may be practical for your situation,some not,but be
aware it is all too easy to buy so called performance bits,and get the
thing to go *slower*
