thermostat & gasket
Guest jimmyrs
Guest jimmyrs
just removed mine - is it meant to be stiff as f*ck to operate? ive put it in boiling hot water and it does absolutely nothing.. so i think im right in assuming this is why im having erratic heating issues?
also, does anyone have the thermostat and o-ring that i could buy? or know where i can get one? need it asap!
thanks guys
Yes, they're supposed to be stiff but if it's not opening when it's in boiling water then it's had it.
Most motor factors should have one - just make sure they give you the correct one (a lot of times they've bought mk3 stats to the counter and I've had to correct them!)
Euro car parts have always supplied mine - £4.56 at the moment :)
Guest jimmyrs
thanks for the info - it did absolutely nothing when placed in boiling water, so im left to assume its had it... have sourced one off ebay for £8 including the o-ring just waiting for it to arrive :tongue:
Guest jimmyrs
my coolant was boiling thats why im replacing the stat, plus it was all manky and looked like rusty water.. not good have flushed it through now and its running clear just waiting for the stat to fit :)
