Argyle dan Posted August 12, 2014 Share Posted August 12, 2014 I need some advice, I have a V161 getrag that's making some funky noises. I'm running a stock flywheel and clutch. The problem is that when I change gear and then put load into the box it's making a cluncking, whining with severe backlash. The gear change itself is smooth, the flywheel and clutch are working fine, but as soon as you apply power/load you start to hear the noises. I've had the car on a ramp and disconnected the propshaft and the noises are still there. http:/youtu.be/gvbd1SGh45c I do apologise for the quality of the video, but you can hear the noises. If any one knows the cause of this and if it's fixable let us know. Cheers Link to comment Share on other sites More sharing options...
David P Posted August 12, 2014 Share Posted August 12, 2014 Maybe the dual mass flywheel is coming apart? (Video not working) Link to comment Share on other sites More sharing options...
Argyle dan Posted August 12, 2014 Author Share Posted August 12, 2014 Clutch and flywheel were near enough new, don't know what's happening with video will have to look at settings, Cheers Link to comment Share on other sites More sharing options...
natony Posted August 12, 2014 Share Posted August 12, 2014 Here you go Link to comment Share on other sites More sharing options...
Argyle dan Posted August 12, 2014 Author Share Posted August 12, 2014 Thanks mate , that's what I was trying to do. Link to comment Share on other sites More sharing options...
keron Posted August 12, 2014 Share Posted August 12, 2014 do it still make the noise if the clutch pedal is pressed all the way down? Link to comment Share on other sites More sharing options...
Argyle dan Posted August 12, 2014 Author Share Posted August 12, 2014 There's a little bit of noise when clutch is fully depressed but it is more when clutch is released and load is put into the box. That's when you hear the clunking etc. Link to comment Share on other sites More sharing options...
Neumann Posted August 17, 2014 Share Posted August 17, 2014 I have the same issue in my car. V160. I belive it to be a bad flywheel after inspection. If Everything is going to plan i Will install a New flywheel on saturday 23 August. I will get back to you if that solves it. Link to comment Share on other sites More sharing options...
Neumann Posted August 25, 2014 Share Posted August 25, 2014 Hey. It was a combination of a bad flywheel and and some issue with the preassure plate. Dont know exactly what is wrong with it. It Works perfectly but i changed that Allso and no problems now. Link to comment Share on other sites More sharing options...
Argyle dan Posted August 25, 2014 Author Share Posted August 25, 2014 Thanks for the reply, I will be taking mine out sometime this week hopefully, I will recheck flywheel and plate , thanks again Link to comment Share on other sites More sharing options...
MRX Posted August 25, 2014 Share Posted August 25, 2014 I think I may have a problem with my flywheel, what involved in getting it out for inspection and what am i looking for? Is it possible to do the drive? Cheers Link to comment Share on other sites More sharing options...
Argyle dan Posted August 25, 2014 Author Share Posted August 25, 2014 Gearbox needs to be removed for proper inspection, I would suggest finding someone with a garage with a 2 post lift or a inspection pit so much easier than trying to do it on a driveway. Also these boxes are bloody heavy. Link to comment Share on other sites More sharing options...
