Guest miklemorr Posted August 12, 2014 Share Posted August 12, 2014 I have a 94 supra turbo swapped standard with the R154 transmission and it cuts off at about 110mph in 4th same thing in 5th I was wondering if it was possible to unlock the speedlimiter or it was just because of the tranny swap!! Quote Link to comment Share on other sites More sharing options...
straightsix Posted August 13, 2014 Share Posted August 13, 2014 You'll need a speed limit remover. Pretty simple to fit. HKS or similar will do one. Quote Link to comment Share on other sites More sharing options...
Guest miklemorr Posted August 18, 2014 Share Posted August 18, 2014 should I but the type 1 (standard) or type 2(auto) because originally the car was auto and you have tu plug it tu the ECU?? help Quote Link to comment Share on other sites More sharing options...
straightsix Posted August 20, 2014 Share Posted August 20, 2014 Probably type 1 as it's now a manual and will be pretty much wired as such. You have to connect ignition controlled live, ground, signal in and signal out - 4 wires in total in the ECU loom. Solder the connections as it's more reliable and won't cause problems with dodgy connectors. I guess you're still using the Auto ECU? Quote Link to comment Share on other sites More sharing options...
