Reyft Posted August 10, 2014 Share Posted August 10, 2014 (edited) !! Edited February 22, 2015 by Reyft (see edit history) Link to comment Share on other sites More sharing options...
Dnk Posted August 10, 2014 Share Posted August 10, 2014 I'd change your thread title mate, you'll get a better response and it'll come up if someone else does a search with similar problem. edit then go advanced to change it Link to comment Share on other sites More sharing options...
Chris88 Posted August 10, 2014 Share Posted August 10, 2014 Could equally be the main crankshaft seal. Link to comment Share on other sites More sharing options...
Ric Posted August 10, 2014 Share Posted August 10, 2014 Could equally be the main crankshaft seal. Does the main crankshaft seal leak transmission fluid? At least read the post. Link to comment Share on other sites More sharing options...
Dnk Posted August 10, 2014 Share Posted August 10, 2014 Is it definitely ATF and not engine oil ? Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 10, 2014 Share Posted August 10, 2014 As Dnk says, are you sure it's red ATF??? If it is I would examine the neck of the torque converter where it enters the gearbox oil pump for scratches, scores or wear grooves. How are you fitting the gearbox and torque converter exactly? If you do it wrong you WILL damage the new pump seal.... The TC *MUST* be put into the gearbox oil pump, turned until the slots in the TC neck align with the oil pump drive dogs, and the TC goes right into the bellhousing, then the gearbox and TC *AS A UNIT* must be offered to the engine. (Or the engine offered to the auto box). Some people bolt the TC to the flex plate and try and fit the gearbox onto the TC. Doomed to failure and damage. EXPENSIVE damage! Link to comment Share on other sites More sharing options...
Reyft Posted August 10, 2014 Author Share Posted August 10, 2014 (edited) Is it definitely ATF and not engine oil ? Thanks for help Dnk.. I'm mechanic & love my job but still learning different kind things about my job.. Yes it is ATF leak. Edited August 10, 2014 by Reyft (see edit history) Link to comment Share on other sites More sharing options...
Reyft Posted August 10, 2014 Author Share Posted August 10, 2014 As Dnk says, are you sure it's red ATF??? If it is I would examine the neck of the torque converter where it enters the gearbox oil pump for scratches, scores or wear grooves. How are you fitting the gearbox and torque converter exactly? If you do it wrong you WILL damage the new pump seal.... The TC *MUST* be put into the gearbox oil pump, turned until the slots in the TC neck align with the oil pump drive dogs, and the TC goes right into the bellhousing, then the gearbox and TC *AS A UNIT* must be offered to the engine. (Or the engine offered to the auto box). Some people bolt the TC to the flex plate and try and fit the gearbox onto the TC. Doomed to failure and damage. EXPENSIVE damage! Thanks for important advices Chris, I done gearbox fitting exactly how you said.. Link to comment Share on other sites More sharing options...
Reyft Posted August 10, 2014 Author Share Posted August 10, 2014 only thing is i'm worry about crack on gearbox or torque converter or can be pump bushes which is converter goes in.. When i check bushes looks was good but i haven't measure it, So any 1 got information about auto gearbox service limits? My english still Poor, trying my best.. Link to comment Share on other sites More sharing options...
Chris Wilson Posted August 10, 2014 Share Posted August 10, 2014 Is it a stock TC? Not painted a bright colour, just plain metal finish? I would check seal again, and check condition of conveter nech where it enters the seal. Your English is perfectly understandable! I can see if the manual gives bush to neck clearances, but I never seen a problem in this area on these cars before. Link to comment Share on other sites More sharing options...
Dnk Posted August 10, 2014 Share Posted August 10, 2014 Thanks for help Dnk.. I'm mechanic & love my job but still learning different kind things about my job.. Yes it is ATF leak. No problem and good luck fixing the leak Link to comment Share on other sites More sharing options...
Reyft Posted August 10, 2014 Author Share Posted August 10, 2014 (edited) Is it a stock TC? Not painted a bright colour, just plain metal finish? I would check seal again, and check condition of conveter nech where it enters the seal. Your English is perfectly understandable! I can see if the manual gives bush to neck clearances, but I never seen a problem in this area on these cars before. Yes Chris converter is std i think!! No any paint on it. I checked converter nech when i fit new original seal no any mark or abrasion there.. Gearbox Breather valve fine aswell.. It was fine and all was perfect, when i take off traction control after 1 day it is happened to me.. I will try send pictures about it, nech & converter and TC bush so easier get idea about It. Edited August 10, 2014 by Reyft (see edit history) Link to comment Share on other sites More sharing options...
