Oil leak from bell housing
Reyft
As Dnk says, are you sure it's red ATF??? If it is I would examine the neck of the torque converter where it enters the gearbox oil pump for scratches, scores or wear grooves. How are you fitting the gearbox and torque converter exactly? If you do it wrong you WILL damage the new pump seal.... The TC *MUST* be put into the gearbox oil pump, turned until the slots in the TC neck align with the oil pump drive dogs, and the TC goes right into the bellhousing, then the gearbox and TC *AS A UNIT* must be offered to the engine. (Or the engine offered to the auto box). Some people bolt the TC to the flex plate and try and fit the gearbox onto the TC. Doomed to failure and damage. EXPENSIVE damage!
Thanks for important advices Chris,
I done gearbox fitting exactly how you said..
only thing is i'm worry about crack on gearbox or torque converter or can be pump bushes which is converter goes in.. When i check bushes looks was good but i haven't measure it,
So any 1 got information about auto gearbox service limits?
My english still Poor, trying my best..
Is it a stock TC? Not painted a bright colour, just plain metal finish? I would check seal again, and check condition of conveter nech where it enters the seal. Your English is perfectly understandable! I can see if the manual gives bush to neck clearances, but I never seen a problem in this area on these cars before.
Yes Chris converter is std i think!! No any paint on it.
I checked converter nech when i fit new original seal no any mark or abrasion there..
Gearbox Breather valve fine aswell..
It was fine and all was perfect, when i take off traction control after 1 day it is happened to me..
I will try send pictures about it,
nech & converter and TC bush so easier get idea about It.
Edited by Reyft (see edit history)
