drift_bear Posted August 9, 2014 Share Posted August 9, 2014 I have checked the back of the new wheels and there's no markings what so ever to tell me the width and ET of them. Doing a tape measure and going by THIS thread they seem to be the following sizes - Front - 9" ET48 (came with 3mm spacers to clear uk brakes) Rear - 10" ET53 The wheels came off a breaker and the shell is long gone. I know they fit the car perfect, but i forgot to check the arches on the other breaker to see if they had been rolled or cut. Any idea if that size above is correct or am i way off?! Quote Link to comment Share on other sites More sharing options...
kitch79 Posted August 9, 2014 Share Posted August 9, 2014 Well they'll fit under any stock arch easy, but without seeing any stamped numbers or even a pic of the wheel ;-) I've no idea if it's correct or not ha. 53 is really high tho. Stock is 50, and they sit waaaay under. (Narrower than 10" tho) Quote Link to comment Share on other sites More sharing options...
drift_bear Posted August 9, 2014 Author Share Posted August 9, 2014 Well they'll fit under any stock arch easy, but without seeing any stamped numbers or even a pic of the wheel ;-) I've no idea if it's correct or not ha. 53 is really high tho. Stock is 50, and they sit waaaay under. (Narrower than 10" tho) Not wanting to give the game away about the new wheels they are going for a refurb soon and will be revealed once the cars finished Quote Link to comment Share on other sites More sharing options...
Chris88 Posted August 9, 2014 Share Posted August 9, 2014 You can measure the offset yourself, like this: Lay the wheel & tyre on the ground (outside up) and measure the distance from the ground to the hub mounting face using a tape rule (DIM A). Turn the wheel over (outside down) and measure the distance from the ground to the hub mounting face again (DIM B). Subtract DIM B from DIM A and divide the answer by 2 to get the offset. EG: DIM A = 167.5mm; DIM B = 97.5mm; DIM A - DIM B = 70mm; offset = 35mm Quote Link to comment Share on other sites More sharing options...
drift_bear Posted August 9, 2014 Author Share Posted August 9, 2014 You can measure the offset yourself, like this: Lay the wheel & tyre on the ground (outside up) and measure the distance from the ground to the hub mounting face using a tape rule (DIM A). Turn the wheel over (outside down) and measure the distance from the ground to the hub mounting face again (DIM B). Subtract DIM B from DIM A and divide the answer by 2 to get the offset. EG: DIM A = 167.5mm; DIM B = 97.5mm; DIM A - DIM B = 70mm; offset = 35mm Will give that a go tomorrow in daylight Quote Link to comment Share on other sites More sharing options...
kitch79 Posted August 9, 2014 Share Posted August 9, 2014 Ooooh I seeeee. Or not ha. Have u got any other wheels with the et and width stamped in? U could use that tape measure method on them and you'd know for def then it's it right as u can check against the actually data. Then if it's the same, 99.9% sure the secret wheel measurements will be as u say in above post. Quote Link to comment Share on other sites More sharing options...
drift_bear Posted August 9, 2014 Author Share Posted August 9, 2014 Ooooh I seeeee. Or not ha. Have u got any other wheels with the et and width stamped in? U could use that tape measure method on them and you'd know for def then it's it right as u can check against the actually data. Then if it's the same, 99.9% sure the secret wheel measurements will be as u say in above post. Haha I'm being secretive about the wheels for a good reason Quote Link to comment Share on other sites More sharing options...
Swampy442 Posted August 9, 2014 Share Posted August 9, 2014 ET 53?? Thats weaker than stock offset. A 10" with that offset will be way inside the arch. Quote Link to comment Share on other sites More sharing options...
kitch79 Posted August 9, 2014 Share Posted August 9, 2014 Example... It'll poke out 15.7mm less than mine show In picture Quote Link to comment Share on other sites More sharing options...
drift_bear Posted August 9, 2014 Author Share Posted August 9, 2014 I've never had to measure before, usually just says on the wheel lol. Will check in the morning though Quote Link to comment Share on other sites More sharing options...
Ric Posted August 10, 2014 Share Posted August 10, 2014 Example... It'll poke out 15.7mm less than mine show In picture http://img.tapatalk.com/d/14/08/10/utuquher.jpg Thats quite a lot, you'll need some spacers alex or it might look poop. Quote Link to comment Share on other sites More sharing options...
drift_bear Posted August 10, 2014 Author Share Posted August 10, 2014 Thats quite a lot, you'll need some spacers alex or it might look poop. I'm hoping ive just miss-calculated the sizes, so will re-do them soon Quote Link to comment Share on other sites More sharing options...
