Ignition coil for 2jzge
daniel4781
Hi.
I suspect my ignition coil have had better days as i am not able to start the car anymore.. :(
Cold readings are: +/- 0.4Ω for primary and 5... MΩ for secondary. :blink:
The current one have this part number: 19080-46030, might not be correct. Some lists: 90919-02197 (?)
I've been looking for a new one but most sites lists 19080-46020 as a replacement one?
What to do? Am i cool as long as the numbers are within specs?
Temps: Cold, Warm
Primary: 0.33 – 0.52 Ω, 0.42 – 0.61 Ω
Secondary: 8.5 – 14.7 kΩ, 10.8 – 17.2 kΩ
Regards
Daniel
Edited by daniel4781 (see edit history)
Any fairly powerful electronic ignition coil with a similar primary resistance should work. Obviously terminals for low and high tension may differ and cause some extra work. The blue Bosch electronic ignition coils DO work, I have used one as a temporary replacement for similar coils for many years. Coils with lower primary resistance may blow up the igniter box....
  • 6 months later...
Hi.
Temps: Cold, Warm
Regards
Daniel
Daniel where did you buy one from in the end? I'm thinking of giving this one a shot:
http://pages.ebay.com/link/?nav=item.view&alt=web&id=291052925472
has anyone else used them?
Hi man.
I ended up buying a used one from ebay with the same part number as i had: 19080-46030. I was i a hurry and not really in the mood to spend that much on one. :-)
Not sure if that will work, try and contact them to get specs on it.
  • 4 months later...
Bumpety again, think my igniter could do with being replaced.
Did the ebay one do the trick in the end? Or is there anyone that does the 19080-46030 in the UK? Prices are all over the place from overseas! Need it quite quickly as well so UK stock would be preferred
