The Raven Posted August 9, 2014 Share Posted August 9, 2014 So i get a FCD a New fuel pump and a double de cat to go with my cat back and some different plugs. If i get a R ring, am i ok to run like that? From reading im likey to see 1 bar? If i want more i should replace the stock side mount and fit a Boost control? Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted August 9, 2014 Share Posted August 9, 2014 Should be fine the run it like that. The boost you'll hit depends on the size of the ring though. Quote Link to comment Share on other sites More sharing options...
The Raven Posted August 9, 2014 Author Share Posted August 9, 2014 I want to be safe so i will get a 1 bar ring, then when i save enough get a BC? is that how things work? Quote Link to comment Share on other sites More sharing options...
Dnk Posted August 9, 2014 Share Posted August 9, 2014 A 1 bar RR is good place to start. You could then fit a boost controller and raise the boost to 1.2 to get the full bpu benefit and around 400 hp at the crank Quote Link to comment Share on other sites More sharing options...
The Raven Posted August 9, 2014 Author Share Posted August 9, 2014 Thanks guys that sounds like a plan, get the simple Bpu then add later Quote Link to comment Share on other sites More sharing options...
Benjy Posted August 9, 2014 Share Posted August 9, 2014 That's how I did mine mate. But I was getting bored of hitting fuel cut, so fitted the BC and my Blitz ECU. You won't want to wait too long. It's addictive. Quote Link to comment Share on other sites More sharing options...
