shetlandsupra Posted August 7, 2014 Share Posted August 7, 2014 Need help how to remove the oil pump do I need to take the sump off? Quote Link to comment Share on other sites More sharing options...
listy Posted August 7, 2014 Share Posted August 7, 2014 Need help how to remove the oil pump do I need to take the sump off? Yes. Crank pulley off. Complete sump off (upper and lower/oil pan) Quote Link to comment Share on other sites More sharing options...
Scooter Posted August 7, 2014 Share Posted August 7, 2014 which involves removing the engine from the car, or dropping the subframe or a bit of both.....essentially you need to make enough clearance between the engine and subframe to remove the sump before you can then attack the oil pump. Quote Link to comment Share on other sites More sharing options...
shetlandsupra Posted August 7, 2014 Author Share Posted August 7, 2014 Okay cheers guys Quote Link to comment Share on other sites More sharing options...
