MRX Posted August 6, 2014 Share Posted August 6, 2014 Got a bit of a problem with knocking/clunking from gearbox/engine area and could use some help with possible causes.... Heavy clunk when pulling away and putting into 2nd Heavy clunk when pulling away and putting into 3rd Not noticeable when selecting other gears In reverse from standstill, lifting clutch and engaging engine there's some heavy clunking Sounds to me like a gearbox/engine mount issue which I know face-lifts are susceptible too. But i'm just concerned it could be a gear box issue? drive shaft issue? Any advice or ideas gratefully received! Thanks Rob Link to comment Share on other sites More sharing options...
MRX Posted August 6, 2014 Author Share Posted August 6, 2014 Anyone want to even have a guess? Link to comment Share on other sites More sharing options...
Wez Posted August 6, 2014 Share Posted August 6, 2014 Have checked the subframe bolts? Link to comment Share on other sites More sharing options...
MRX Posted August 6, 2014 Author Share Posted August 6, 2014 Haven't checked anything yet mate, only had the car a few days but need some suggestions as to what to check first. Link to comment Share on other sites More sharing options...
Wez Posted August 6, 2014 Share Posted August 6, 2014 OK, check subframe bolts are torqued up, gearbox mounts, diff mounts and engine mounts. The 6 speeds are very clunky anyways but worth checking Link to comment Share on other sites More sharing options...
tooquicktostop Posted August 6, 2014 Share Posted August 6, 2014 I replaced my engine and gearbox mounts after similar issues which took the clunking away Worth mentioning I replaced them with TRD mounts which are so stiff you could hear every gear change and gear, rather annoying , stock would have been better result As mentioned the 6 speed is very agricultural and takes some getting used to, I dislike the box if I am honest, only positive is the power it can take Link to comment Share on other sites More sharing options...
Scooter Posted August 6, 2014 Share Posted August 6, 2014 Could be the flywheel? what happens at idle if you move to the bite point....just find it as normal first then try a more rapid lift to it. ie can you make things 'clunk' without actually moving? Drive shafts aren't known problem unlikely to be anything to do with them. just sitting there in neutral get someone to rev the car fairly high, blip it and come of the throttle completely while you watch the engine rock....does it move alot? Link to comment Share on other sites More sharing options...
MRX Posted August 7, 2014 Author Share Posted August 7, 2014 Thanks for the comments guys I'll check some of these things out tonight. Link to comment Share on other sites More sharing options...
MRX Posted August 25, 2014 Author Share Posted August 25, 2014 Bit of an update. I've changed the gearbox mount and gearbox oil which has smoothed it out a bit. But i'm still getting a clonk when I dip the clutch and it disengage's the drive, almost like the flywheel is loose. Is that even possible or likely? Link to comment Share on other sites More sharing options...
LOGIE Posted August 25, 2014 Share Posted August 25, 2014 could it possibly be the donut? or even the prop may have a loose bolt. make sure you have checked all the basics (diff included) and easy to get to stuff before you start pulling out the gearbox to see the flywheel. Link to comment Share on other sites More sharing options...
