Power steering pump gasket?
mac79
I have a leak on my power steering pump, it where the pipe connects from the Reservoir on to the top of the pump. It looks like the plate bolts on and there would be a gasket, that where the leak is.
If that is the case can you buy a new gasket? the pump still works and i have been topping it up but it has now got worse so time to fix.
If it's not really nice and supple I'd change the hose from the reservoir to the nipple, too. they have a nasty tendency to split when you disturb old ones, plus they weep if they are no longer soft and get disturbed. A leak at that O ring is common, so it should sort it :)[/quote ]
Thanks for the tip I will check that before i take it off.
