Speed limiter removal??
Bally
Hi All,
I have a 1995 twin turbo auto Japanese import and when driving it today when the speed reaches 130 mph the engine cuts off (doesn't misfire just coasts) then when the speed drops a bit to 115 mph it pulls again upto 130 mph then stops what is the easiest way to remove this limiter?
All replies gratefully receieved:)
Hi All,
You must be sending in this post from Germany.
A cut off at 130mph is unusual as its usually 112 or 155. To take it to the upper limit you need to go along the lines of fitting one of these:
http://thor-racing.co.uk/Electronic_Speedo_Convert-THOR00497.asp
