BPU upgrade tuner near Sheffield
Bally
Hi all,
I am wanting to upgrade my 95 auto TT Supra to BPU (removal of 1st decat uprated fuel pump etc) I use a mechanic who I know well he can fit all the parts the only thing which I think might be a problem is fitting a boost gauge itself as I think it needs to be set up on a rolling road/dyno does anyone know of a good setup near Sheffield? as always any advice gratefully received
Are you meaning a boost controller mate? As above a gauge won't need any set up. Once the boost controller is fitted it's just a matter of applying the settings and away you go. Not every car needs a boost controller though. Some cars will raise boost on their own with the double decat. For safety though I'd go 1bar restrictor ring and raise boost with BC to 1.2. :)
Thanks for your reply Kraig I thought you needed a boost gauge as well if one is not needed it will simplify the job next question wheres the best place to buy the bits needed??
Regards
- - - Updated - - -
Yes I meant boost controller:)
Just to recap when the Bpu parts are fitted including a restrictor ring is it not possible for the car to produce more than 1 bar of pressure aka (a safe level of boost) don t wanna fit the parts and damage the engine!
You fit a 1 bar restrictor ring then you install a boost controller to raise the boost to 1.2bar or 1.4bar depending on if you have a jspec or UK (or j spec with hybrids) as tony said.
A boost gauge is a nice to have, technically not really needed if all BPU upgrades are fitted correctly.
