NSF Hub play (video)
Rummy
Hi all
Just doing some brake anti-squeak maintenance and wheel cleaning and discovered this on the NSF hub:
http://youtu.be/TBWQSGJKAOc
Is it likely to be some hub retaining bolt loose? Is it easy to locate and service without some horrendously priced "special tool" or does it look U/S and better off getting another hub?
I havn't noticed any knocking or adverse activity from that side with the wheel bolted up but it's probably not doing the bolts any good under braking in the long term with that movement, so need to get this sorted one way or the other as soon as.
Thanks in advance
