zaheer0027 Posted August 3, 2014 Share Posted August 3, 2014 Please help me. I have been reading threads posted about owners who have had a similar issue and if I am not mistaken these lights work with an integration relay located on the drivers kick panel. I have checked both fuse boxes as well as 1a fuse located under the steering panel and no issues there. Is it safe to assume the integration relay is my problem? Nb. All other interior and exterior lights work fine. Thanks in advance Link to comment Share on other sites More sharing options...
zaheer0027 Posted August 3, 2014 Author Share Posted August 3, 2014 Also this is a 94 j spec sz if it makes any difference. All parts are oem and not aftermarket Link to comment Share on other sites More sharing options...
listy Posted August 3, 2014 Share Posted August 3, 2014 Iirc both the ignition surround light, and (definitely) the footwell lights, were optional extras. Are you 100% sure your Supra has them installed? Link to comment Share on other sites More sharing options...
zaheer0027 Posted August 3, 2014 Author Share Posted August 3, 2014 Yes 100% I have pulled out the loom holding these bulbs. Also these lights were working before i accidently cut through the horn connector. Link to comment Share on other sites More sharing options...
