Andrew K Posted August 2, 2014 Share Posted August 2, 2014 For the build I'm doing it's going to be a 6 spd v161 single turbo, the engine loom I'm using is from a TT auto! I know this isn't a problem to use and one of the plugs needs modifying. The black plug near the back of the gear box is the speed sensor and the plug on the auto loom is the same so they fit no problem. The plug on the other side is the one that doesn't fit the auto loom, I know you have to cut the big plug off the auto loom and join 2 wires together and the 2 others need to go to the plug that's on the box, I want to fit the original plug onto the auto loom so it matches the original plug on the box Does anyone know or can help with the number I need to order this? There is a small 5 digit number that's on the plug which I need to order one. The other side of the plug which is on the box has this part number on it if it helps any 11050. This is the plug I'm on about and want the original male version to fit it. On the big plug from the auto loom you have to join the black & black / white wires together, the next 2wires with the red & yellow arrows pointing to them need to go to the manual box but which way round do they have to connect to the wires on the gearbox? Or doesn't it matter they can go either way round once you've fitted the plug on the end? Link to comment Share on other sites More sharing options...
Andrew K Posted August 4, 2014 Author Share Posted August 4, 2014 Can anyone help? Link to comment Share on other sites More sharing options...
ColinBJones Posted August 9, 2014 Share Posted August 9, 2014 Hi Andrew, very interesting thread. I am about to fit a 2jz gte that has auto box loom to a NA Supra with 6 speed Getrag. Your information will be invaluable but sorry I can't help with your query. Link to comment Share on other sites More sharing options...
Andrew K Posted August 16, 2014 Author Share Posted August 16, 2014 Just spoke to Steve at inchcape Toyota and he can't order the plug without the part number as there's so many to choose from Has anybody got a manual loom they could look at? or in a position where your working on your car and you can have a look at the plug I'm after and get the part number off the plug I need? I need the plug on the loom that plugs into the plug in the second picture above. Link to comment Share on other sites More sharing options...
Andrew K Posted August 16, 2014 Author Share Posted August 16, 2014 At last I've spent quite a few hours today trawling through the internet and have found what I'm looking for, the part number for the plug that needs replacing on the TT Auto Engine loom harness is 90980-11051, this will keep it all nice and original with no need to use rubbish aftermarket plugs instead! Link to comment Share on other sites More sharing options...
SPG Posted August 16, 2014 Share Posted August 16, 2014 Top work Andrew Link to comment Share on other sites More sharing options...
