Stock turbo CHRA replacement
Ric
Hi Guys,
I have some smokey turbos. I either want to pay to rebuild or perhaps do them myself, I'm not too bad with some spanners i've done my own stem seals etc before.
I came across this on ebay:
http://www.ebay.co.uk/itm/TURBO-BALANCED-CHRA-CARTRIDGE-TOYOTA-SUPRA-TWIN-TURBO-CT12-/281388062156?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item41840915cc
The main problem with referbing your own turbos i think is down to balancing, but these CHRA units are complete, balanced.
What is stopping me just opening my stock turbos and replacing the centre piece?
Is it that simple, or am i missing something?
Cracked turbine housings are the bug bear of these turbos, usually around the port of the wastegate on the front turbos. If yours are not cracked, or not badly cracked these might make for cheap rebuilt turbos. Only way to find out is to buy and try ;) It should be that simple...
But I'll tel you something for nothing. If it / they fail, you won't get a refund, in all the years I have bought exchange turbos, if they fail it's *NEVER* their fault. Always "wrong oil, bad fitment, blocked oil feeds, low oil pressure, abuse, dirt in the system, bad air filtration, overheating, stuck wastegate", blah blah. The sales people must have a sheet to read off until they learn the excuses parrot fashion :) This is why I will only fit *NEW* turbos unless the customer accepts a failed recon unit is *NOT* down to me, labour and parts wise, to remove and replace. See their disclaimer, seems very broad and ready to spring into action. In fairness all turbo rebuilders seem to take this attitude. Maybe because they are critical devices and they *DO* get their share of numpties fitting them wrongly or abusing them...
Lots of labour that I only want to do the once, unless paid to do it multiple times, it's not like fitting an alternator... But I would be very interested how you get on if you buy these.
Edited by Chris Wilson (see edit history)
I know the disclaimers are adequate, but even if i only got 10,000 miles (that could be 5 years for the amount i drive mine) it's not a bad investment at 250-300quid? over 1000 getting them done professionally.
Ill have to get the turbo's off first and see if theres any cracking first then decide what to try.
It's rare to find any housings without cracks these days. The situation is not as bad as for the Mazda FD rotary engines, where the huge heat makes them crack horrendously and even burn away, but short of buying new ones it's going to be hard to find used front turbos with no cracks.
Will be very interesting to see how you get on if you go down this route. I too have looked at these several times and wondered what's involved. I just had the MOT on mine done today and I covered less than 1500 miles since the last so 10,000 suits me fine. Good luck if you do go ahead Ric and please let us know how you get on.
I've been researching this the last few days and watched many videos on CHRA replacement and im starting to worry that it looks incredibly simple to do, perhaps too easy, a few simple bolts once the turbos are off.
I think I'm 100% going to try this myself.
Can anybody confirm the jspec 94 TT is a CT12 turbo, conflicting reports on here regarding CT12 or CT20 and various A B C models.
Im not around my car to see, but i expect identification will only be 100% when my turbos are off.
So it is a CT20...
based on those part numbers the following should be fine -
http://www.ebay.co.uk/itm/Turbo-Turbocharger-CHRA-Core-Cartridge-17201-54010-1720154010-17201-54010-CT20-/321046791772?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item4abfe1465c
They can be had for less than £100 on ebay, however this seller seems to be a better supplier.
Guest CombatSanta
Please let us know if you decide to do this. :)
I think it would be wonderful to have like a guide with pictures and stuff..
I looked into doing a similar thing some time ago. I suppose it would depend on how bad your old turbos are. Once the shaft has play, the blades scrape on the housings and wear them away especially the front alloy compressor housing.
So even when you replace the chra with a brand new item, there is that extra gap between the housings and blades which will reduce the turbo efficiency. By what degree I don't know.
  • 2 weeks later...
I work out of the country so i wont be starting this for a few weeks.
However.
From my discussions from companies who supply the CHRA's it seems there are VAST differences between models, it would be nearly impossible to get the right CHRA first time, or the 2nd, perhaps the third, even with the CHRA identification numbers.
Could be a nonstarter.
  • 1 year later...
I've done a lot of research on this over the last few days and I have come to conclusion that j-spec run ct20 and uk spec run ct12b. If your turbos are ct12b it will be stamped on the compressor housing and if they are ct20 there will be no such stamp. Hope this clears it up. [emoji51]
