fuel pump voltage
Alex
How do you run a fuel pump at 13.5volts, when your battery/electrical system is only rated at 12?
What would I need to change to be able to run the pump at a higher voltage?
NB: I don't want to do the 12v pump mod - this is a seperate question.
Guest Martin F
The thing to remember is that even though you may have 13.5v at the front of the car you may not see that at the fuel pump in the rear. The reason being is because it's quite a long run for the cables and our pumps draw quite a lot of current so any resistance in that run (or particularly the earth) will have an adverse effect on the voltage seen.
To be 100% you really need to measure the voltage as close to the pump as possible (and measure it across the terminals) and if you do see a lower than desired voltage check all connections, particularly the earth ones.
Good point Martin and the UK pump does draw a huge amount of current relative to it's flow abilities.
The Walbros use much less current whilst being a more efficient pump. So much so that many can run twin Walbros on the stock wiring. Try that with 2 UK pumps and you will not only have red-hot wires you will probably trip the fuse and/or fuel pump ECU.
Nathan
TDI PLC
I've just measured mine... (Sad, I know), I'm getting 13.88 measured directly across the battery with the engine running, and 13.56 at the pump and the pump ECU, (Walbro pump).
I suppose if you wanted to be ultra fussy, you could use a relay to make a direct connection to the battery but I doubt 0.3 volts would make any significant defference anyway.
i thought it was 14.4 vplts when car was running. if you that concerned you could always relocate the batterey to boot like the skylines have.
what sort of price are the twin walbro pumps and is it overkill for stock turbos. was looking at the power house racing fuel system, that has 2 walbro fuel pumps think it was a stage 2 fuel kit.
what have you got planned alex?
12 volt is a very general term for car electrics. The 12v mod basically means stopping the pumps ecu from dropping to the lower voltage (9v approx - 8.7 when I measured mine at idle).
The 12v mod as described on mkiv.com wires the pump to 12v all the time the ignition is on... I didn't like the idea of that much so I wired mine slightly differently.
I've wired mine through a 5-15 volt relay that makes the pump see 12v, (or maximum available voltage), when the engines actually running. *
If that doesn't make much sense, feel free to call me tomorrow - 01622 683044
* Just waiting for Pete Betts to pop along and explain how to make it more simple... :innocent:
That sounds like a very good idea Matt.
Guest Martin F
Originally posted by Alex Holdroyd
So where did they get the "12v fuel pump mod" come from ;) :sly:
As Matt say's it's just an arbitrary term. Do you want to be the one to rename it to the "12.8v to 14v fuel pump mod" ?
:p
I'm not adverse to running better cabling to the back from the battery....
if I was to get some should I use
70A Car Battery Cable,
40A In Car Ent cabling,
or just 20-30A Twin Power Cable?
All of those are listed in the Maplin Catalogue....
Matt, Is there any chance you could document your mod for an FAQ/idiot like me? :)
.......I think the plug on the battery is going to need an overhaul too!!
No problem Alex, I'll have a look at the wiring colours I've used and post it up later.
Personally, I wouldn't bother running new cables, just do the wiring conversion at the pumps ecu. Unless you're meter gives you low readings at the ecu.
When measureing the voltage, ideally, get someone to hold the RPM over 1000 to make sure the alternator is at full strength. The figures may/will fluctuate slightly.
