Squeaky brakes
JK90
Are the anti squeal plates in? Have you changed the pads and discs recently and forgot to replace them.
Not sure mate, will take off at weekend and have a look, I havnt changed pads or discs, just got it recently from jm.
Sometimes pads without a chamfered edge cause as squeal due a 90 degree angle on the pad edge making contact with the disc. If you chamfer the edges to 45 degree 9 times out of 10 eliminates the squeal. I've done this hundreds of times.
