NA auto to manual conversion
Bluudy
Guest Roger NE
No, very much cheaper, as the N/A gearboxes are often changed if people turbocharge their engine.
You need:
W58 gearbox with bellhousing, clutch fork and slave cylinder (and
Flywheel and 8 flywheel bolts
Complete Clutch kit with pilot bearing and release bearing (best get all this new if you can afford it)
Clutch and brake pedals
Clutch Master Cylinder
Clutch hydraulic line
Manual Propshaft
You may also need the gearbox support cross member if it's different
Think that's mainly it . . . you could get the lot from one scrap car (I'd be offering ~£400 in total)
You also need to do a bit of wiring modification, to short out the wires to the auto start switch
Edited by Roger NE (see edit history)
I am just in the process of changing to manual I just fitted the pedals and master and slave cylinder is all in place ready to swap boxes and fit fly wheel and clutch I have the prop there to and gearbox cradle I did not know that the tunnel needed swapping though is there a lot of persuasion required to get it to fit into the auto tunnel
