Dan8 Posted July 28, 2014 Share Posted July 28, 2014 Am in the process of converting my auto naturally aspirated to manual turbo and just removed all my manual parts from my donor When I got the gearbox removed I was checking over it and noticed some slight movement side to side in the shaft that connects to the clutch is this anything to worry about Quote Link to comment Share on other sites More sharing options...
Dazzi Posted July 28, 2014 Share Posted July 28, 2014 Mine had slight movement from side to side. Never had any problems. Forwards and backwards I would worry! Quote Link to comment Share on other sites More sharing options...
Guest Roger NE Posted July 28, 2014 Share Posted July 28, 2014 That's why you have a Pilot Bearing in the middle of the flywheel to locate and support the end of the shaft ! (so as it was an Auto, do make sure you fit one!!) Quote Link to comment Share on other sites More sharing options...
