haz182 Posted July 26, 2014 Share Posted July 26, 2014 so i have a uk 94 supra and it failed its mot on a front position lamp not working and a arm ball joint dust cover.. simple things i thought,, after being to several places for this lamp bulb no where has it or even seen such a bulb... i got tell monday to find one or to use a different bulb.. dose anyone know where i can find one or if a different more common bulb will fit? or is their a local uk supra owner local to me who would like to lend me theirs!! Quote Link to comment Share on other sites More sharing options...
Nic Posted July 26, 2014 Share Posted July 26, 2014 If have j-spec headlights use 9005/HB3 bulbs in the low and high beam, you will need to trim a rib on the connector that plugs into the bulbs on the low beam. http://www.mkivsupra.net/vbb/showthread.php?142251 Quote Link to comment Share on other sites More sharing options...
Scott Posted July 26, 2014 Share Posted July 26, 2014 9006/HB4 for UK spec. Quote Link to comment Share on other sites More sharing options...
haz182 Posted July 26, 2014 Author Share Posted July 26, 2014 i dont mean the main beam bulb.. if you look at the drivers side head unit, the first light on the left.. nearest the wing.. is a small LEd looking bulb.. has two pins, one longer than the other.. Quote Link to comment Share on other sites More sharing options...
Scott Posted July 26, 2014 Share Posted July 26, 2014 Sounds like a custom one to me. Furthest to the left as you look at it is the fog light. H3 bulb for that one, as standard. I doubt anyone knew what you meant by "position lamp bulb", never heard that term used before. Quote Link to comment Share on other sites More sharing options...
