Compression Results
Noz
Guest Roger NE
Yes if the compression comes up if you put a teaspoon of oil down the plug hole on No 5, then it's faulty rings . . . otherwise it's a valve problem or your head gasket.
No matter what the cause, I expect it's why you have your poor running/missfire
The fact that No 4 is showing a good figure, but all the rest are a fair bit lower is not a good sign either. (last time I checked mine they were almost all the same)
