Elmo Posted July 25, 2014 Share Posted July 25, 2014 Need to replace my brake lines, might as well get braided ones. There are quite a few makes to choose from, some apparently fit better than others so I would like to know which are considered to be the best fit. Which would you recommend? Thanks. Quote Link to comment Share on other sites More sharing options...
charlton Posted July 25, 2014 Share Posted July 25, 2014 I got the Goodridge ones from Whifbitz and they seem all good to me Quote Link to comment Share on other sites More sharing options...
gordy.r Posted July 25, 2014 Share Posted July 25, 2014 I think it's DoLuck ones that are on my Supe, can't complain, seem to do the job! Quote Link to comment Share on other sites More sharing options...
dandan Posted July 26, 2014 Share Posted July 26, 2014 I have a set of unused Goodridge ones you can purchase if you like. Let me know the best price you find and I'll beat it including postage. No use to me any more, they're just in a box in the garage. Quote Link to comment Share on other sites More sharing options...
Elmo Posted July 26, 2014 Author Share Posted July 26, 2014 I have a set of unused Goodridge ones you can purchase if you like. Let me know the best price you find and I'll beat it including postage. No use to me any more, they're just in a box in the garage. Cool, I'm interested. Do they have the S/S or Zinc plated fittings? Cheers! Quote Link to comment Share on other sites More sharing options...
dandan Posted July 27, 2014 Share Posted July 27, 2014 I'll check and get back to you.. Quote Link to comment Share on other sites More sharing options...
Dnk Posted July 27, 2014 Share Posted July 27, 2014 I'd have a look at the hard lines too Quote Link to comment Share on other sites More sharing options...
David P Posted July 27, 2014 Share Posted July 27, 2014 I think it's DoLuck ones that are on my Supe, can't complain, seem to do the job! I have a set of those on mine, they work fine, but the homosexual pink plastic coating soon looks shabby and then begins to fall off. Quote Link to comment Share on other sites More sharing options...
Elmo Posted July 27, 2014 Author Share Posted July 27, 2014 I'd have a look at the hard lines too I think they're in good condition, but will check them when I replace the flexi ones. Cheers Quote Link to comment Share on other sites More sharing options...
safcdixon Posted July 27, 2014 Share Posted July 27, 2014 I think it's DoLuck ones that are on my Supe, can't complain, seem to do the job! One of mine burst outa the blue the other week at a dyno day, Then when I got home after fitting a borrowed stock one I checked it over, I mananged to pull the two parts apart very easily I think the turning and swivel of the wheel somehow degraded the steel near the banjo end? or maybe mine was defective (they were fitted for nearly two years though) So if you have doluck braided lines fitted check them over for any splits in the pink lining or the braided steel part Quote Link to comment Share on other sites More sharing options...
Dnk Posted July 27, 2014 Share Posted July 27, 2014 BF Goodridge on my car for over 5 years and no issues before i sold it, st/st fittings are a must though Quote Link to comment Share on other sites More sharing options...
David P Posted July 27, 2014 Share Posted July 27, 2014 One of mine burst outa the blue the other week at a dyno day, Then when I got home after fitting a borrowed stock one I checked it over, I mananged to pull the two parts apart very easilyhttp://i224.photobucket.com/albums/dd214/safcdixon/DC623D46-822C-4924-B344-05F667054AA1_zpssusbwcyi.jpg I think the turning and swivel of the wheel somehow degraded the steel near the banjo end? or maybe mine was defective (they were fitted for nearly two years though) So if you have doluck braided lines fitted check them over for any splits in the pink lining or the braided steel part I've yet to see aftermarket flexi hoses that have location tabs, which makes it easy peasy to fit them with a twist and consequently, with use can/will result in the above. Quote Link to comment Share on other sites More sharing options...
safcdixon Posted July 27, 2014 Share Posted July 27, 2014 I've yet to see aftermarket flexi hoses that have location tabs, which makes it easy peasy to fit them with a twist and consequently, with use can/will result in the above. Yeah I thought it strange that a "uprated" part listed as made for a certain type of car didn't have the location tabs like the stock hoses do, for the cost of braided lines they would be made to at least oem spec! luckily mine burst as the dyno guy got in the car to put it on the dyno, he put in gear mine being an auto he pressed the brake pedal to select, he then said your brake lines just burst , so I wasn't on the road with no brakes, lucky escape. Quote Link to comment Share on other sites More sharing options...
MattP Posted July 27, 2014 Share Posted July 27, 2014 Ive had a few genuine sets on both UK and J spec brakes and can honestly say they make bot all difference for me....Hel,Goodridge,Exact etc etc. I like the standard ones :/ Quote Link to comment Share on other sites More sharing options...
