Replacement o2 sensors
daniel4781
Hello guys.
I've been looking around a bit now and i can't seem to find any posts that has working replacement o2 sensors with M18 threads for mkiv n/a jspec.
Any of you guys who have some tips on what to look for, or if you know some that works?
I have been buying some universal ones, but it does not look like they work. (although voltage seems right when measured, idk how sensitive they are. 0,2 - 0,7 seems about right?)
Regards
Daniel
Guest Roger NE
Yes single wire universal ones should work fine.
Aftermarket ones usually have a screw-in thread (like a spark plug) - but for a couple of quid you can buy adaptors, which have a 2-bolt flange, like on the Supra. (make sure you get gaskets with them too)
Once you've fitted the adaptors, it's MUCH easier to change the O2 sensors in the future, as you just unscrew it - you don't have the worry of the little studs shearing . . and you don't have to fit new gaskets!
  • 2 weeks later...
Thanks for replies. :-)
Heh, for some weird reason the computer kept saying it was the o2 sensors that was failing when it actually was the wrong spark plugs... // Some fool(previous owner) put in plugs with 1.6mm gap..! -,-
So i swapped em out for some proper ones and it hasn't given me any trouble yet. =D Awesome since the sensors was cheap, like 10 quid ea.
