paulj1 Posted July 22, 2014 Share Posted July 22, 2014 Does anyone know what size the bolts are that hold the fuel tank cover on and also what size the silicone hoses are on the bov as mine have gone brittle and split Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted July 22, 2014 Share Posted July 22, 2014 Pretty sure the bolts are m6, but not sure of length. Bov hose is 18mm from memory Quote Link to comment Share on other sites More sharing options...
paulj1 Posted July 22, 2014 Author Share Posted July 22, 2014 Brilliant cheers Gaz is silicone hose all the same as will order some off of eBay if it's allbthe same sort of stuff Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted July 22, 2014 Share Posted July 22, 2014 Pretty much mate yes. Make sure you buy the reinforced wall stuff, normally 3 layer silicone. The cheap vacuum hose in that diameter can go all floppy and collapse over time. Quote Link to comment Share on other sites More sharing options...
MattP Posted July 22, 2014 Share Posted July 22, 2014 Don't buy silicone for the stock BOV it won't bend to shape without kinking and looking shit just get proper Mr T ones Quote Link to comment Share on other sites More sharing options...
paulj1 Posted July 23, 2014 Author Share Posted July 23, 2014 It's got ssqv on it and also I have a hose that's split going into the green plastic valve on the top near the cam cover/second actuator Quote Link to comment Share on other sites More sharing options...
MattP Posted July 23, 2014 Share Posted July 23, 2014 paulj1 said: It's got ssqv on it and also I have a hose that's split going into the green plastic valve on the top near the cam cover/second actuator Got a pic? Quote Link to comment Share on other sites More sharing options...
