SupraStar 3000 Posted July 22, 2014 Share Posted July 22, 2014 Been doing a few jobs on the Supra recently including adding some tasty bits and bobs under the hood. Now I find the tatty under bonnet heating material looks very old. What have you guys used to replace this???? I'd ideally like mirrored or white, but open to suggestions and ideas. Thanks, and Peace out! Quote Link to comment Share on other sites More sharing options...
chazuk Posted July 22, 2014 Share Posted July 22, 2014 I would remove it and have the underside re-sprayed Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted July 22, 2014 Author Share Posted July 22, 2014 Just dont like the idea of heat blistering the paint. Quote Link to comment Share on other sites More sharing options...
ripped_fear Posted July 22, 2014 Share Posted July 22, 2014 Im in the same position edd. I remember rob had some carbon cut to sit in the indents of the bonnet. Could paint the rest. Ive considered mirror wrap in the indents and paint the rest. Quote Link to comment Share on other sites More sharing options...
Mk4Gaz Posted July 22, 2014 Share Posted July 22, 2014 Just dont like the idea of heat blistering the paint. It won't mate, unless you've got a huge single glowing red hot with no heat shield Quote Link to comment Share on other sites More sharing options...
Abz Posted July 22, 2014 Share Posted July 22, 2014 Isn't that the fire blanket?! Quote Link to comment Share on other sites More sharing options...
Guest Budz86 Posted July 22, 2014 Share Posted July 22, 2014 Mines been fine at BPU for the 3 years I've had it....and she gets roasting hot! Quote Link to comment Share on other sites More sharing options...
jim Posted July 22, 2014 Share Posted July 22, 2014 You could try Keron for good condition used one Edd? Quote Link to comment Share on other sites More sharing options...
Gaz6002 Posted July 22, 2014 Share Posted July 22, 2014 Heating? It's not for heating! Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted July 23, 2014 Author Share Posted July 23, 2014 heating sheeting! You all know what I mean I'll take off the old stuff and have a look at the feasibility of spraying the underside white. I'd expect more traders to sell the stuff as I can't fined the material anywhere? Mind you, I am looking for heating sheeting Quote Link to comment Share on other sites More sharing options...
Hassan Posted July 23, 2014 Share Posted July 23, 2014 You can use the dynamat hoodliner. Quote Link to comment Share on other sites More sharing options...
The Raven Posted July 23, 2014 Share Posted July 23, 2014 Its a fire blanket. If the engine was to catch fire it would melt the lugs and fall onto said engine, it does nothing when the engine is not on fire Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted July 23, 2014 Author Share Posted July 23, 2014 never knew that Raven! wow,.... I find new things about my car every day Thanks bud Quote Link to comment Share on other sites More sharing options...
Abz Posted July 23, 2014 Share Posted July 23, 2014 Err am I on block?! I said that earlier Quote Link to comment Share on other sites More sharing options...
The Raven Posted July 24, 2014 Share Posted July 24, 2014 Who posted above me I can't see I blocked them Quote Link to comment Share on other sites More sharing options...
JamieP Posted July 24, 2014 Share Posted July 24, 2014 Just dont like the idea of heat blistering the paint. It won't, I always remove it, never had a paint issue. Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted July 24, 2014 Author Share Posted July 24, 2014 Err am I on block?! I said that earlier Sorry Abz, When I saw you here, I started to knock one out,.. so didn't see the text. xx Quote Link to comment Share on other sites More sharing options...
SupraStar 3000 Posted July 24, 2014 Author Share Posted July 24, 2014 It won't, I always remove it, never had a paint issue. Cheers Jamie. Appreciated Think I'll get it removed this weekend then. Quote Link to comment Share on other sites More sharing options...
Chris Wilson Posted July 24, 2014 Share Posted July 24, 2014 IMO it's a simple sound deadener. A flattish piece of material dropping on top of the engine is NOT going to make any difference whatsoever to a fuel fire Quote Link to comment Share on other sites More sharing options...
Hassan Posted July 24, 2014 Share Posted July 24, 2014 (edited) IMO it's a simple sound deadener. A flattish piece of material dropping on top of the engine is NOT going to make any difference whatsoever to a fuel fire I agree 100% Like i said before. If you want sound deading or heat shield or something that looks nice. Then google Dynamat Hoodliner. It will do all the things your looking for. Its that simple. Edited July 24, 2014 by Hassan (see edit history) Quote Link to comment Share on other sites More sharing options...
gavin.starr Posted July 24, 2014 Share Posted July 24, 2014 IMO it's a simple sound deadener. A flattish piece of material dropping on top of the engine is NOT going to make any difference whatsoever to a fuel fire I think its one and only purpose is to protect the user in an event of a fire, say for example there was a fire under the bonnet, the plastic lugs melt and the matting drops onto the engine. So then if you see smoke under the bonnet and you lift it up you dont get the back draught of flames up in your face. Saying that though every car i have owned ive removed it and will be doing on mine soon too as it looks to have gone slightly mouldy. Quote Link to comment Share on other sites More sharing options...
Hassan Posted July 24, 2014 Share Posted July 24, 2014 I think its one and only purpose is to protect the user in an event of a fire, say for example there was a fire under the bonnet, the plastic lugs melt and the matting drops onto the engine. So then if you see smoke under the bonnet and you lift it up you dont get the back draught of flames up in your face. Saying that though every car i have owned ive removed it and will be doing on mine soon too as it looks to have gone slightly mouldy. Try it for yourself. First with the oem heatshield and then without. It only does two things. 1st: you will notice the engine noise is louder since there is no sound deading material now. 2nd: your bonnet will be alot hotter to touch since there is no heat shielding now. Its that simple. See if your engine was on fire and the fire was hot and big enough to be melting plastic clips (by this time your car will be in a big fire ball) who in there right mind will want to stand near it and open the bonnet to check??? I dont get this concept at all. Depending on which plactic its made from, your taking about melting points from 115c to 270c. So being a engine bay i presume the plastic will have a higher melting point. So if your bonnet is burning at 250c plus will you be able to touch it or go near it??? No chance. Its only purpose is to sound deading and heat shield. Thats all. Quote Link to comment Share on other sites More sharing options...
The Raven Posted July 24, 2014 Share Posted July 24, 2014 I tried to burn mine 3 hours on a pallet fire melted it in the end. If itsfor sound deading only then they used the best flame retardant material iv ever come across Quote Link to comment Share on other sites More sharing options...
j_jza80 Posted July 24, 2014 Share Posted July 24, 2014 They're hardly likely to use anything particularly flammable Quote Link to comment Share on other sites More sharing options...
The Raven Posted July 24, 2014 Share Posted July 24, 2014 They're hardly likely to use anything particularly flammable 3 hours, is a long time on a pallet fire, i got rid of 50 before it melted into goo. Quote Link to comment Share on other sites More sharing options...
